zc swaped rex
i did a dohc zc swap into my rex and i got the swap out of a hatch (btw....its a 1990 crx dx if that info is needed).....i tried to use the axles from the hatch but the part that goes into the spindle for the rotars was too small for my rex so now i need new axles so i can drive it.....what kind of axles do i use??? ive heard some cases of integra axles but not all the info i need, i need straight up information on what axles i need to use so i can drive my rex with the zc swap thanks guys
what do you mean by trim level???? if i am thinkin what ur thinkin then its a dx and i also dont know what tranny is on there thats what i need to find out too so i can just go tell them i have that car so say it was a d16 tranny i could just tell them i have a 1990 crx dx but it could be any kind of d series tranny and i dont know how to identify them either
yeah it was a standard....when i first got axles i told them it was a 90 rex si since the motor is out of a 89-91 si and i figured it was the tranny it came with so i didn't say anything about the swap because it would have confused them but i got the si axles and the driver side would fit in but then the passenger side doesn't fit so somewhere those two sides are different or somehow they gave me the wrong ones....i have no idea
They must have given you wrong axles then. If they were both si or dx axles then both would obviously work.
Axles from any trim level will work with any tranny, its just the outside of the axle that is smaller with the std trim.
eumoria
12
Aug 8, 2004 07:04 AM
