obd0 obd1 and dpfi mpfi conversion
https://honda-tech.com/zerothread/1508680
https://honda-tech.com/zerosearch
https://honda-tech.com/zerouser?cmd=logout
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vasilas7588 »</TD></TR><TR><TD CLASS="quote">i have a 91 crx dpfi obd0 and i just droped a 15b motor into it need help wireing</TD></TR></TABLE>
This helps no one. You are having what problem? You have done what work? You are using what wiring harness? You are using what ECU? If you want help we need a lot of details.
Well, since you had to do everything at once, http://www.rywire.com . Personally though, I'm a believer of doing it piece by piece to make sure everything is right. DPFI--> MPFI, work out all the bugs. OBD-0 MPFI --> OBD-1 MPFI, work at all the bugs.
that be nice. no i dont have any instrutions an i dont no what wire goes where
what are all the extra wires for
should i convert mpfi first
i no when converting mpfi you need a resister box but do obd1 injectors use them
Tensa_Zangetsu
23
Nov 23, 2008 08:09 PM
