relocating ground wire...
Its very easy, fold the back seat down, there will one braket on each side under the gray carpeting (held down with little velcro squares in the bottom corner). Take a 10mm socket and remove both that fasten the braket to the seat back. Once complete, remove seat back. On the seat bottom there will be a thin metal strap that is in line with the seat belt buckle (can be seen by looking at gap that is shown by removing the seat back). Use a 10mm socket with an extension to remove the bolt hodling the metal strap to the body of the car. You will then push the seat belt buckles through the holes in the seat, and pull the rear part of the seat bottom towards the front of the car, you can then wiggle the hooks out of the floor of the car and remove the seat bottom.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverjdmcoupe »</TD></TR><TR><TD CLASS="quote">Its very easy, fold the back seat down, there will one braket on each side under the gray carpeting (held down with little velcro squares in the bottom corner). Take a 10mm socket and remove both that fasten the braket to the seat back. Once complete, remove seat back. On the seat bottom there will be a thin metal strap that is in line with the seat belt buckle (can be seen by looking at gap that is shown by removing the seat back). Use a 10mm socket with an extension to remove the bolt hodling the metal strap to the body of the car. You will then push the seat belt buckles through the holes in the seat, and pull the rear part of the seat bottom towards the front of the car, you can then wiggle the hooks out of the floor of the car and remove the seat bottom.</TD></TR></TABLE>
Sweet ***... thanks...!!! Yea I figured out the top part of the back seats, just never the bottom part.
soberstan
12
Oct 22, 2004 12:01 PM
