Skunk2 S3 cams TOO Big for my setup????
Old Dec 3, 2006 | 06:42 PM
spooledex's Avatar
Default Skunk2 S3 cams TOO Big for my setup????
I am about finished with the winter project, even though it's only Dec. But wondering if my cams are too big for the motor I have built or will do fine. Here's the setup:
B20 block 84.5 with wiseco 2cc dome pistons suppose to be 11.5
Head and block milled .020
Ported Type R head with stock valves and RLZ dual valve springs and retainers.
ITR manifold with 70mm TB
Tri Y header 2.0
2.5 Thermal Catback with high flow cat
370 RC injectors
Tuning with AEM EMS
Overall compression should be about 11.7-11.8. Can someone tell me if these cams are too much for the motor or should I go with something milder.
Old Dec 3, 2006 | 06:54 PM
b19coupe's Avatar
Default Re: Skunk2 S3 cams TOO Big for my setup???? (spooledex)
The cams are not too big.
Old Dec 3, 2006 | 07:05 PM
spooledex's Avatar
Default Re: Skunk2 S3 cams TOO Big for my setup???? (b19coupe)
I can get my hands on a set of toda b's but I don't think that will be enough though.
Old Dec 3, 2006 | 07:51 PM
Ass$nyper's Avatar
Pirate General...YARRRR
I think they would work fine, with your setup.
Old Dec 3, 2006 | 08:11 PM
UncleD's Avatar
Default Re: Skunk2 S3 cams TOO Big for my setup???? (Capt. Blonde Beard)
S2 Pro2/RM M24x would be some good choices
Old Dec 3, 2006 | 08:30 PM
spooledex's Avatar
Default Re: Skunk2 S3 cams TOO Big for my setup???? (clean rice)
Aren't Pro 2's bigger than the stage 3's? I am just asking if these will do fine. I don't want to go to a bigger cam. These stage 3's look a lot bigger than the toda C's I had in the type R. Thanks for the help. Should have dyno up in 2-3 weeks.
Old Dec 3, 2006 | 08:38 PM
UncleD's Avatar
If you have the S2S3's, yeah...run em.
Old Dec 3, 2006 | 10:01 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooledex &raquo;</TD></TR><TR><TD CLASS="quote"> These stage 3's look a lot bigger than the toda C's I had in the type R. Thanks for the help. </TD></TR></TABLE>
ah yes, the ol' eye micrometer
Old Dec 4, 2006 | 09:31 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: Skunk2 S3 cams TOO Big for my setup???? (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">
ah yes, the ol' eye micrometer</TD></TR></TABLE>lmao IMO the skunk3s are very good cams should compliment your setup perfecty
Old Dec 4, 2006 | 02:42 PM
getgot22's Avatar
Default Re: Skunk2 S3 cams TOO Big for my setup???? (WHITFIELD-TUNED)
see sig for almost identical setup..
kennie555
Feb 22, 2013 12:45 PM
YoungMoneySi
Oct 16, 2007 08:56 PM
xQB21x
25
Sep 22, 2007 12:13 PM
fmrprojects
Feb 1, 2006 11:40 AM
deftones0817
Jul 15, 2004 05:48 PM
