CF sunroof plug: anybody have one
Does anyone have the CF sunroof plug. If so do you have any noticable difference in handling. I know that you are removing a lot of weight from the top of the car and creating a lower center of gravity for the vehicle. What I want to know is it worth $400.
just by removing 30 lbs or so will not improve your handling. but it's a requirement for the nasa honda challenge that you block it if you have a sunroof. if that's the case. just remove your backseats and passenger seat. take that $400 and get a itr sway bar and performance shocks.
30lbs removed from the roof should reduce body roll slightly. Heck, I'll even venture to say by at least 1%.
CF is overkill for that application. A better question to ask is "does anyone make a fiberglass plug for the sunroof"?
Eresuncabron
Jan 2, 2004 02:34 PM
