i wanna go all motor
ok so heres the deal i want to go all motor but i dont no were to start i have i/h/e but after that i dont no were to start. I have about $1500 to spend. Any and all help would be greatly appreciated. I have a 95 gsr with 117,000 miles. all and any help would be great. id be doing the work by myself.
THANKS FOR ANY HELP OR INPUT
ID GREATLY APRECHIATE IT
Add a jdm 4.7 FD or the MF Factory 4.9 FD. Type r cams/Blox IM/some sort of engine management and have it tuned. You do those 3 and you'll **** your pants at the difference. Some valevtrain wouldn't be a bad idea either cuz you're gonna want to rev higher, I can gaurentee it.
*EDIT*
MF Final Drive - $550ish... https://honda-tech.com/zerothread?id=1592797
Used 01' ITR cams - $300 https://honda-tech.com/zerothread?id=1695985
Blox IM for gsr - $150 http://www.prostreetonline.com...10100/
Hondata/Crome Pro/Neptune - $250ish
$1,250. I have type r valvetrain that I could sell you also, have it tuned and there is your $1,500 wisely spent.
Modified by clean rice at 5:38 AM 12/4/2006
*EDIT*
clean rice, labor to install that FD would be $$$ though.
maybe buy an itr tranny, then sell the gsr.
not only will you have a better final drive, but better gearing and also an LSD already installed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ipodhustle »</TD></TR><TR><TD CLASS="quote">clean rice, labor to install that FD would be $$$ though.
not only will you have a better final drive, but better gearing and also an LSD already installed.</TD></TR></TABLE>
DIY FTW! grab a helms manual and dig in.
My gear set cost me $125 for installation. Are the FD's really that much harder? I carried my tranny in also, so it wasn't like he had to pull it out of the car. I am scared to do any tranny work myself
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">Add a jdm 4.7 FD or the MF Factory 4.9 FD. Type r cams/Blox IM/some sort of engine management and have it tuned. You do those 3 and you'll **** your pants at the difference. Some valevtrain wouldn't be a bad idea either cuz you're gonna want to rev higher, I can gaurentee it.
*EDIT*
Modified by clean rice at 5:38 AM 12/4/2006</TD></TR></TABLE>
very good advice
*EDIT*
very good advice
spyderman_8_2
16
May 3, 2006 06:29 AM
