Friend was following behind and saw black smoke out of my muffler!??!?!
Old Dec 3, 2006 | 01:29 PM
CrazyRexBoy's Avatar
Default Friend was following behind and saw black smoke out of my muffler!??!?!
hey guys.... earlier i went to meet up with some friends...and we decided to go to the mall and they had to follow....then a Civic Hatch was messing with me so we ran for a bit... then my friend told me that when my VTEC started to hit.... a cloud of black smoke came out.... but when i turned on my engine and left it in the parking lot and started to rev it up...i dont see any black smoke ...its perfectly clean... does that mean something is wrong? someone said something bout a Ring being burnt? please let me know guys...thanks...
my only mods are... intake,headers,msd spark system, and pulleys... the exhaust is 100% stock...
Old Dec 3, 2006 | 01:40 PM
90Integra_Rs's Avatar
Default Re: Friend was following behind and saw black smoke out of my muffler!??!?! (CrazyRexBoy)
How many miles are on the motor?
Old Dec 3, 2006 | 01:44 PM
PrinceAli132's Avatar
I believe its common to have some black smoke when getting into vtec. Your piston rings can be going bad, so that might be something to look into. Try doing a compression and/or leakdown test.
The reason why I think you might not see any smoke when your reving is because vtec will not activiate if its not under any load.
Ali
Old Dec 3, 2006 | 01:55 PM
Default Re: Friend was following behind and saw black smoke out of my muffler!??!?! (PrinceAli132)
my car only has 88k miles.... and my friend said it was alot of black smoke...just a cloud of small black smoke coming out ...
Old Dec 3, 2006 | 01:56 PM
it wasnt alot of smoke* sorry..
Old Dec 3, 2006 | 02:16 PM
PogKai's Avatar
maybe it's running rich
Old Dec 3, 2006 | 04:03 PM
gsr converters's Avatar
what kind of intake do you have, intake manifold?
Old Dec 3, 2006 | 07:04 PM
sixfiveoh's Avatar
Sweet Title
Default Re: (gsr converters)
maybe your friend is just dickin you around
yea earlier i had a compression test done on my engine...and its normal...it happens that i am running a bit rich because of my ECU and some of the parts i have as well... maybe ill just sell the ECU and stuff..get it back to stock...thanks tho guys...
Old Dec 3, 2006 | 07:25 PM
Default Re: (CrazyRexBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyRexBoy &raquo;</TD></TR><TR><TD CLASS="quote">yea earlier i had a compression test done on my engine...and its normal...it happens that i am running a bit rich because of my ECU and some of the parts i have as well... maybe ill just sell the ECU and stuff..get it back to stock...thanks tho guys...</TD></TR></TABLE>
So are you running a stock ecu or a chipped one? Honda ecu rarely go bad so selling the ecu wouldnt change the engine from smoking. Have you ever changed the o2 sensor?
H22SHtec
Sep 11, 2010 05:45 PM
egblack94
Dec 7, 2008 02:25 PM
Seraph
Nov 11, 2006 05:27 AM
danny_305
May 11, 2005 03:45 AM
FLCivic
Feb 19, 2003 07:10 PM
