H22 swap into 6th gen accord
1. Brake pedal for manual tranny
2. Clutch pedal assy(comes with starter interlock switch)
3. Clutch master cyl assy
4. Line from clutch master cyl to Dampener
5. Dampener assy with mounting bracket (fender side)
6. Line from dampener to clutch slave cyl hose (rubber line)
7. Clutch hose (connects line from dampener to clutch joint on tranny)
8. Clutch joint (junk yards may leave it on the tranny)
9. Line from joint to clutch slave cyl (junk yards may leave it on the tranny)
10. Clutch slave cyl (junk yards may leave it on the tranny)
11. Manual tranny assy (of course...hehe)
12. Speedo sensor (junk yards may leave it on the tranny)
13. Clutch assy (press. plate, disk, & throw-out bearing)
14. Flywheel
15. Manual ECU (you can use AT ecu but it will throw out error codes)
16. Shifter assy (which includes lever & base plate)
17. Shift cable, holding clips, clevis pins, cotter pins
18. Starter for manual tranny
19. Tranny mount & bracket
20. Shift boot and ****
21. 30-amp relay (for starter interlock)
22. Driver's side CV shaft and intermediate shaft
Please correct me if any of this info is incorrect or If I left a part out.
http://www.hmotorsonline.com
14. Flywheel
hondafreak2134
Jan 1, 2010 06:40 PM
