Honda S2000 Honda S2000
Slicks on stock rims
Old Dec 3, 2006 | 12:24 PM
Widebodys2k's Avatar
Default Slicks on stock rims
ive been googling for a couple hours trying to find slicks that will fit the stock AP1 rims, i cannot find anything, if anyone knows a website to buy or is selling a set, thanks in advance
Old Dec 3, 2006 | 05:51 PM
JG-Fabrications's Avatar
Default Re: Slicks on stock rims (Widebodys2k)
hoosier sells a 28x10 for the stock wheel
-James
Old Dec 4, 2006 | 07:12 AM
lsvtecarod's Avatar
Default Re: Slicks on stock rims (JG-Fabrications)
you dn't need slicks on an s2k, people pulling 1.4 60fts on drag radials
Old Dec 4, 2006 | 08:56 AM
S2SLOW's Avatar
Default Re: Slicks on stock rims (lsvtecarod)
Nitto 555R's is all u need!!!!
Old Dec 4, 2006 | 09:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecarod &raquo;</TD></TR><TR><TD CLASS="quote">you dn't need slicks on an s2k, people pulling 1.4 60fts on drag radials</TD></TR></TABLE>
when I was running 590whp the best I could muster on a 245 bf goodrich drag radial was a 1.95 spinning the hell out of frist/and 2nd yes I did a johnforce burnout and the tires were at 10 psi....
on that run I killed it at the 1/8th and coasted an 11.8 @ 120 because the soft top popped up on the drivers side (oops missed the latch lol)
-James
Old Dec 4, 2006 | 10:32 AM
lsvtecarod's Avatar
lol that must have been scary. I know a couple people who ran 10s on nitto 555rs with 1.4 60fts
Old Dec 5, 2006 | 04:57 PM
lol everything was fine I hit 120mph and boom a huge gust of air hit me in the helmet I was like wtf, let off the gas and looked up it was messed up lol
I bet had I kept going it would have ripped the top off, on that run I was going against a mustang 68 he ended up running a 10.5 he got a 1.38 60 foot he had me by like 5 cars at the launch but by the 1/8th mile I was right beside him he must have been freaking out seeing a honda bout to whip him, too bad the top fubar'd I would have had him by about 1 car lenght at the end
on side note it is a good thing the top happened, on that run the pump for the air/water intercooler got clogged with a piece of the bag from the ice, basically I had no intercooler and with charge temps getting around 400 degress I dont think it would have been pretty at the end had I not shut it down lol
-James
Old Dec 5, 2006 | 05:06 PM
blkturbos2k's Avatar
I did the same damn thing but I kept going. I held the top down with one hand and drove with the other. I had to let go to shift. I didnt see it til the top of 3rd
Old Dec 5, 2006 | 05:15 PM
Default Re: Slicks on stock rims (blkturbos2k)
mang you crazy I not taking my hand of the wheel at 120 + and dont want my right arm flying up in my view to hold it in meantime of shifting lol
Yah mine didnt happen till all of a sudden untill the near the top of 4th
-James
Old Dec 5, 2006 | 05:19 PM
whats funny is that was my fastest time so far
Old Dec 5, 2006 | 05:24 PM
lol crazy, i had no cage in mine so I was prepared to be booted off the track, I was also keeping that in the back of my mind incase anything happed lol
I not afriad to go all out anymore, 10 point cage, parachute setup, 5 point harness's I feel safe as can be lol
-James
Old Dec 5, 2006 | 07:16 PM
I have the same stuff going in my car. I just dont want a parachute if I dont need it. I belive you have to pull the chute @ 150
Old Dec 5, 2006 | 10:36 PM
best i went so far was rather shity, it was my first time ever running a car at the track, my sixty foot was horrible put it this way i coulda got hooked on fonics in the time of my sixty foot but i wont say it lol, but the mph was 127. and it was a 12.8
i believe chute was 135 pull at 150
Old Dec 6, 2006 | 04:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkturbos2k &raquo;</TD></TR><TR><TD CLASS="quote">I have the same stuff going in my car. I just dont want a parachute if I dont need it. I belive you have to pull the chute @ 150</TD></TR></TABLE>
We are going to be maxing out a gt4294r turbo and spraying n2o I am pretty sure with that kinda power we will be running a bit faster than 150 mph
-James
Old Dec 6, 2006 | 04:51 AM
I assume that the car will be making more then 700rwhp. I hope you tub the car. You really cant put much more to the ground then that
Old Dec 6, 2006 | 06:52 AM
yah you can put a good tire on
with a 15x10 with 8" backspace you can fit a 10.5" tread width wide slick on it (it has 1/4" clearance to inside of fender and to rear frame lol but it does fit, thank god the slicks get skinnier as you go not fatter
stick with soft springs, good wheelie bar, it will be ripping
to fit those wheels you have to go over to a shock that doesnt have a external resivor (koni yellows is what I chose)
after that it all bolts up but is super tight, the brake calipers only have like 1/8" clearance to the wheel hubs lol darn honda had to put huge brakes on s2k
-James
Old Dec 6, 2006 | 07:06 AM
Belive me I know. You also want a shock with little valving under comp. But you want a good bit when it trys to recoil
HotboxedTypeR
Apr 3, 2007 10:56 PM
SiKnezzALLmotor
Aug 2, 2006 10:53 PM
racingfan
Jul 14, 2006 08:29 AM
Drew Peacock
Apr 15, 2004 01:36 AM
