1990 accord oil leak (searched)
hello all this is my first post ask for help a
a friend of mine gave me an accord . it has oil leak very bad bottom of timing-belt cover( when engine is running)please help
Another problem is when i jack the car up and put in gear Only the one on the driver side axle spin. Is this bad axla or something?
There's a few things that leak into that area. The oil pump is there, as well as the front main seal, camshaft seal, & balancer seals. Timing covers have to come off to see what's leaking. If it's the camshaft, you'll see it with just the upper timing cover.
In order to remove the lower timing cover, you have to remove the crankshaft pulley. Then you can see the other stuff.
cam seal will not leak at bottom of lower t-belt cover,, you will notice the leak at the back of the engine between the block and the head
most likely you got a balancer shaft seal leaking or popped out ,, 90-97 accords very notorious for that ,, as a matter of facts there was a recall , to install a retainer on the bal shaft seal
masospaghetti
Sep 22, 2014 05:31 AM
MacR6
Jan 2, 2014 09:35 PM
ellen44
Sep 18, 2008 10:43 AM
