oil leakage.. Help
Old Dec 3, 2006 | 06:47 AM
cwhat's Avatar
Default oil leakage.. Help
yea so i haven't been driving the 90 civic for a month and i just checked my spark plugs and the plubs are soaked with oil. Also, i have no idea where the oil is leaking from the car. I checked the oil filter, oil pan gasket, and head gasket there all fine. I have no idea where the oil is leaking from when i turn on the car..
Old Dec 3, 2006 | 06:52 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: oil leakage.. Help (cwhat)
Check the o-rings on the valve cover. You can get a oil leaking from there.
Old Dec 3, 2006 | 07:12 AM
zccr-xsi's Avatar
ever looked at them spark plug seals?round thing on the underside of the valvecover.have u look around the head are to see if oil is leaking from inbetween the head and block.
Old Dec 3, 2006 | 07:19 AM
Duane_in_Japan's Avatar
Default Re: (zccr-xsi)
Get a valve cover gasket set, valve cover gasket, spark plug o rings and washer seals under the bolts that hold the valve cover to the head (if you have them). Also replace the PCV Valve and grommet and rubber PCV hose. End of problems.
Pull spark plugs, spray down the area with carb cleaner, clean the wires really good, crank the engine with the plugs removed to blow out most of this mess, lay an old towel across the volve cover to catch most of this spray. Re-install clean plugs and wires, start engine and burn all the oil / carb cleaner mix out of the engine until it stops smoking, drive around and kill a few bugs.
Old Dec 3, 2006 | 07:45 AM
fireant's Avatar
Default Re: (Duane_in_Japan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">Get a valve cover gasket set, valve cover gasket, spark plug o rings and washer seals under the bolts that hold the valve cover to the head (if you have them). Also replace the PCV Valve and grommet and rubber PCV hose. End of problems.
Pull spark plugs, spray down the area with carb cleaner, clean the wires really good, crank the engine with the plugs removed to blow out most of this mess, lay an old towel across the volve cover to catch most of this spray. Re-install clean plugs and wires, start engine and burn all the oil / carb cleaner mix out of the engine until it stops smoking, drive around and kill a few bugs.</TD></TR></TABLE>
Great sig duane.
Old Dec 3, 2006 | 10:53 AM
project midnight's Avatar
I had the same problem. get a new valve cover gasket set on that bitch and you'll be fine
LoveBrisk
Honda CR-V & Element
Jun 30, 2014 06:31 AM
keychild486
Aug 15, 2008 04:12 PM
B16A JDM EG
Dec 4, 2007 03:44 PM
BlueRex1020
Feb 8, 2007 09:17 PM
froger
Feb 3, 2005 12:39 PM
