motor problems.. need help
Old May 10, 2002 | 12:50 AM
[626]95-GSR's Avatar
Default motor problems.. need help
Tonight i was driving around, pushing my car a little. Stop at a red light.. get up to 4k rpm and motor dies.. backfiring when i was on the gas a little, let off the gas and it died. Tried to start it, turns over fine.. but it wont start, and it starts to backfire while its turning. Check for any leaks, everything seems fine. Check for spark in each wire, thats fine.
Well heres the diagnosis: clogged catalytic converter? spark plugs had oil on them, bad plugs? timing belt jump a tooth? distributor is messed? i tried to pop start it; it started, but ran like crap, backfiring the whole time, let off the gas and it died. it was almost as if it was running on one cylinder.. im totally stumped. im hoping its not a mechanical failure such as the pistons.. need help please.
Old May 10, 2002 | 01:14 AM
Kamin's Avatar
Default Re: motor problems.. need help ([626]Rj-SiHatchy)
plugs had oil on them?
wich plugs? (e.g. cylinders 1, 2, 3, 4)
me thinks you need to do a compression test.
because the plugs had oil on them its possible they werent igniting in the cylinder
i would do a compression test asap.
[Modified by KAMiN, 2:15 AM 5/10/2002]
Old May 10, 2002 | 01:28 AM
Default Re: motor problems.. need help (KAMiN)
thanks... well the plugs are coming out tomorrow. The o-rings were probably messed up, and oil got on to the plugs.. Im also going to look into a distributor, but it did have spark, so the distrib should be fine. The compression APPEARS to be fine, but i gotta check. I think the spark plugs are fouled, i found oil in #1,#2,#3, and #4.. ive had oil in them before, nothing went wrong.
Thinking back, i was having problems with my car.. it just started to happen recently too. It was throwing a code. When i would drive my car the motor would lose power all the sudden at a set RPM (example: 2000rpm, 3000rpm) It would jump back into power again. it was really annoying. The car would go, stop, and then go again.. it jolted the car.
Old May 10, 2002 | 01:49 AM
aeolus's Avatar
sounds like it could be a map sensor problem.
Old May 10, 2002 | 06:04 PM
Default Re: motor problems.. need help (aeolus)
any other suggestions?? im leaning more toward a distributor problem.. it was squeaking a little before this happened.
96civic909
10
Oct 15, 2008 05:54 AM
IAD_ek
15
Oct 17, 2007 06:59 PM
blkwidow420
May 24, 2004 02:35 AM
sshaikh01
May 31, 2002 08:08 AM
[626]95-GSR
May 10, 2002 06:06 PM
