searched with no luck...98-01 integra with acura tl HID's?
Old Dec 2, 2006 | 09:14 PM
a1320addict's Avatar
Default searched with no luck...98-01 integra with acura tl HID's?
Was at the junkyard today and picked up a HID setup out of a newer TL.
Anyway, I figured I would pick them up, being I wan't too sure how to retrofit into my headlight housing.
I'd like to know if someone could point me in the right direction? I know the bulbs do not have the same "socket" type, I wanted to know what I need to purchase to make the HID's compatible? I'd like as OEM an install as possible.
TIA
Old Dec 2, 2006 | 11:54 PM
Desired_Speeds's Avatar
what year was the TL? G2 TL or G3?
Old Dec 3, 2006 | 12:02 AM
johnny hatchback's Avatar
Default Re: (Desired_Speeds)
i'm not sure what your particular HID's look like but here is the way one guy did it. It comes out somewhat oem looking.
http://www.skafia.com/itr/hid/
Old Dec 3, 2006 | 05:29 AM
Default Re: (johnny hatchback)
I believe it was a 05 TL
Old Dec 3, 2006 | 07:04 AM
Padawan's Avatar
Darth ModerVader
Default Re: searched with no luck...98-01 integra with acura tl HID's? (a1320addict)
The best advice I can offer is to sell the setup you found, and then purchase one made for 9006 housings. As you know, drop-in kits aren't ideal, but if you want to use one in your stock halogen projectors, you really want capsules that have proper bases for your application. It is important that the correct focal length is maintained, and also that they seal well.
Old Dec 3, 2006 | 07:55 AM
chahsiubow's Avatar
how much did you get those from the junkyard for?
Old Dec 3, 2006 | 10:33 AM
Default Re: (chahsiubow)
paid 200..the junkyard sold me a broken navigation system that they guaranteed, so he knocked off some price.
Padawan, is it possible to keep the ballasts and use a 9006 bulb?
Old Dec 3, 2006 | 11:03 AM
Padawan's Avatar
Darth ModerVader
Default Re: (a1320addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">Padawan, is it possible to keep the ballasts and use a 9006 bulb?</TD></TR></TABLE>
It would depend upon which capsules you bought. Some use a proprietary connector, but you may be able to find properly based capsules that are compatible with standard ballasts.
Old Dec 3, 2006 | 11:38 AM
Default Re: (Padawan)
hm...well thanks everyone for your input.
if anyone knows a way to make this a plug-n-play direct fit, let me know
Old Dec 3, 2006 | 11:44 AM
underpressure02's Avatar
make sure you seal those ballast very well or mount them somewhere, where they will not get wet. I had a set in my dd and they burnt out b/c water got in them where the white plastic piece is.
Old Jan 13, 2007 | 01:35 PM
Default Re: (underpressure02)
sorry to bring it back from the dead, but would these work?
http://www.hidexpert.com/
9006 re-based
http://www.hidexpert.com/new/H7-D2R.jpg
[ej]Jonathan
Lighting
Dec 14, 2011 05:31 PM
GEEESER
Sep 19, 2004 08:02 AM
crxmadman
Dec 29, 2003 06:11 PM
TurbothisLS
Jan 10, 2003 06:59 AM
