1994 Prelude VTEC, Towing Capacity?
Old Dec 2, 2006 | 08:06 PM
The Phil's Avatar
Default 1994 Prelude VTEC, Towing Capacity?
Given a trailer hitch, how much could my Prelude tow? Is there anything I should do before towing things with the Prelude? I plan on doing a 60k maintenance routine over the winter, should I be adding anything else in while the car is apart?
Thanks.
Old Dec 2, 2006 | 08:08 PM
mgags7's Avatar
You will know very quickly what kinda shape your clutch is in....
Just take it easy on the thing when taking off....its gonna kill your clutch if your payload is heavy
I don't really think anyone has good numbers on what the lude can actually tow though...
Old Dec 2, 2006 | 08:11 PM
The Phil's Avatar
Default Re: (bb4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">You will know very quickly what kinda shape your clutch is in....
I don't really think anyone has good numbers on what the lude can actually tow though...</TD></TR></TABLE>
The clutch is being replaced actually, because it's having problems moving the car, much less a payload. Should I be looking at some manner of aftermarket clutch, as a kind of peace of mind type thing?
Looks like I'm going to be testing what the towing cap on the car is. I'm hoping to tow my Rx7 to the track once the season starts again.
Old Dec 2, 2006 | 08:12 PM
InvaderTrax's Avatar
I wouldn't tow more than a jet ski
Old Dec 2, 2006 | 08:19 PM
The Phil's Avatar
Default Re: (InvaderTrax)
Looking around, the capacity on the hitches I'm finding is 2000lbs. Blah.
I wonder if the limiting factor is the hitch itself or the frame of the car.
Old Dec 2, 2006 | 08:21 PM
mgags7's Avatar
Why dont you tow one POS with the other?
You're probably better off renting a truck for the weekend or something...
Old Dec 2, 2006 | 08:31 PM
LudaChris's Avatar
Is your RX7 not streetable?
Old Dec 2, 2006 | 08:40 PM
Rosko's Avatar
Default Re: (The Phil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Phil &raquo;</TD></TR><TR><TD CLASS="quote">Looking around, the capacity on the hitches I'm finding is 2000lbs. Blah.
I wonder if the limiting factor is the hitch itself or the frame of the car.</TD></TR></TABLE>
haha, what frame? I think that might be pushing it a little. you'd be towing as much weight as what you're pulling it with.
Old Dec 2, 2006 | 08:47 PM
The Phil's Avatar
Default Re: (LudaChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudaChris &raquo;</TD></TR><TR><TD CLASS="quote">Is your RX7 not streetable? </TD></TR></TABLE>
It's "streetable". It'll continue to be "streetable" for at least a season, so I'm not too pressed about towing it at the moment.
The main reason I want to be able to tow it is so that I can slap race rubber and brakes on it the day before, and not have to worry about things when I'm at the track. I'm not going to be competing during the upcoming season though, so I'm not going to have to worry about it until next year.
At the moment, I'm just wondering if I should be looking for another car as a tow vehicle (looks like that's what I should be doing) or not.
Old Dec 2, 2006 | 08:50 PM
A Blue Lude's Avatar
Default Re: 1994 Prelude VTEC, Towing Capacity? (The Phil)
The RR/AC guys probably have the greatest understanding (on H-T) of towing and tow vehicles.
You're going to need something a little more truck-like to safely pull another car, though.
Old Dec 2, 2006 | 09:21 PM
CGags13's Avatar
yea dude i hear ya with the brakes, tires, and not worrying
yea id search around for a 2wd toyota or nissan..you can find a fixer upper for cheap..besides those 22re and ka24s last forever..
ill be copping one of those for myself in the spring...then i can make the egg nasty..and i can stop carrying pool chemicals and equipment around in a h22 hatch
Old Dec 3, 2006 | 12:44 AM
BB4-Japanpower's Avatar
750 kg with unbraked trailer
1200 kg with braked trailer
hope this helps
Old Dec 3, 2006 | 05:18 AM
pinecone's Avatar
Default Re: (BB4-Japanpower)
I wouldn't try towing a trailer and a car that weighs more than the tow vehicle itself. I would invest in a nissan or toyota to pull the car with. The Lude will thank you.
Old Dec 3, 2006 | 06:00 AM
godslayer's Avatar
At the moment, I'm just wondering if I should be looking for another car as a tow vehicle (looks like that's what I should be doing) or not.</TD></TR></TABLE>
Pick up a mid 80's to mid 90's full size pickup with a 6 cylinder (I like a Ford F150 with the 4.9L straight six) and a big rear differential (3.3:1 or better) for a couple hundred bucks. That'll pull a car for sure and you wont break it.
Old Dec 3, 2006 | 06:05 PM
92hondalude's Avatar
Default Re: (godslayer)
damnit phil...
what are you doing to your lude man!
Old Dec 3, 2006 | 08:59 PM
mgags7's Avatar
Default Re: (92hondalude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">damnit phil...
what are you doing to your lude man!</TD></TR></TABLE>
yea next he is going to be putting ls1s in preludes
Old Dec 3, 2006 | 10:37 PM
The Phil's Avatar
Personally, I'm not doing anything to it.
Recently though, my friend's sister ran it into an SUV. It's going to be fine though
Old Dec 4, 2006 | 04:52 AM
kulrevon's Avatar
I have towed two different civics with my h22 lude.
One was a ls/turbo hatch that fried the rings. with two people in it I pulled it about 30 miles down the highway. I left the a/c on by accident. The hardest part is actually trying to figure out where to rev it out to so when you switch gears you don't bog or spin the clutch.
I also towed a coupe with a broken axle about 10 miles.
The thing is when I towed these it was with a tow strap so the rear car has to slow the front car. which isn't bad when they are around the same size cars. (lude and civic.) I had a friend tow a crx with an ford expo and they over heated the brakes on the crx trying to keep the tow line taught.
I would be afraid of the brakes overheating on the lude from trying to stop the ls1 powered rx and itself.
Old Dec 5, 2006 | 02:37 AM
numark34's Avatar
I would do the tow with my lude revving aint a problem when u float the gears at high rpm after all thats where all the tork and hp is at but I would have the hitch put un by a pro
arrogantmeat
Apr 22, 2013 08:37 AM
h22_crx
Oct 16, 2005 07:35 PM
micmasta
Sep 7, 2004 04:08 AM
Jago
May 19, 2003 09:03 PM
