CRX Cluster Shroud
I recently bought a CRX and have seen 2 different kind of cluster shrouds... one is square (like mine in my 89 dx) and the other is rounded, like i've seen in some pictures. I would like to get a rounded one, does anyone know whether it would fit with no modification ? And if so, where could i find one?
I've got plans for my CRX and i'll post pictures as soon as i get some decent work done. Got some body to do and i'll be rebuilding an SiR 1st gen.
Thanks
Thanks
If im not mistaken, your talking about the 88-89 cluster and the 90-91 cluster, the 90-91 is rounded and does plug into the 88-89 EF but im not sure if all functions will work like the light in the middle that read Park, Reverse, etc.
Shrouds easily swap between 88-89 and 90-91. The Gauge cluster however requires you swap over the metal brackets that match the cluster. Wiring DOES change between years, and maybe even models. I compared my 89 CRX HF cluster to the 90/91 CRX HF cluster I have and they are wired slightly different. Easy as pie to de-pin and switch.
Ok thank you both for the quality information
I was in my friend's 91 civic hatchback dx today, and i beleive he has the same rounded cluster cover as the one i saw in a CRX, is it the same?
The cluster wiring doesnt really matter as i am changing it to an SiR cluster anyways, so the wiring would have to be done either way.
