specs on gsr
Old Dec 2, 2006 | 03:29 PM
jikespingleton's Avatar
Default specs on gsr
does anyone know any websites that has every spec i would need to know about my motor. when i say specs, i mean torque specs and pretty much every little detail i need to known about the motor and how to rebuild it properly.
Old Dec 2, 2006 | 03:30 PM
aaronISthrowed's Avatar
Default Re: specs on gsr (jikespingleton)
Look in the FAQ, it some the specs there.
Old Dec 2, 2006 | 03:54 PM
Leo C's Avatar
Night Owl
Get a Hilton, Chaynes or Helms manual. Great investment for 15-20$
Old Dec 2, 2006 | 04:37 PM
doood's Avatar
been there done that
grab a helms manual or go here and sign up http://www.hondahookup.com/manuals/
Modified by that one doood at 2:10 AM 12/3/2006
Old Dec 2, 2006 | 07:27 PM
bigbucksGSR's Avatar
Integra
Year Model Engine Generation Displacement
CC's Compression
Ratio Horse
Power Torque Country
97-98
-2000 type R B18C5 3G - DC 1797 10.6 : 1 195 @
8000 rpm 130 lb/ft @
7500 rpm USA
- 97-98 Gsr B18C1 3G - DC 1797 10.0 : 1 170 @
7600 rpm 128 lb/ft @
6200 rpm USA
-94-00 Ls / Rs
-Gs B18B1 3G - DC 1834 9.2 : 1 142 @
6300 rpm 127 lb/ft @
5200 rpm USA
-95-97 Si R B18C 3G - DC 1797 10.6 : 1 178 @
7600 rpm 129 lb/ft @
6200 rpm Japan
-95-00 type R B18C5 3G - DC 1797 11.0 : 1 197 @
8000 rpm 134 lb/ft @
7500 rpm Japan
-90-91 Gs B18A1 2G - DB 1834 9.2 : 1 130 @
6000 rpm 121 lb/ft @
5000 rpm USA
-92-93 Gs B18A1 2G - DB 1834 9.2 : 1 140 @
6300 rpm 121 lb/ft @
5200 rpm USA
-92-93 Gsr B17A1 2G - DB 1678 10.0 : 1 160 @
7600 rpm 117 lb/ft @
7000 rpm USA
-90-93 ZC 2G - DB 1590 9.0 : 1 119 @
6300 rpm 105 lb/ft @
5500 rpm Japan
-90-93 X Si
R Si B16A 2G - DB 1595 10.2 : 1 158 @
7600 rpm 112 lb/ft @
7000 rpm Japan
-88-89 D16A3 1G - DA 1590 9.5 : 1 118 @
5500 rpm 103 lb/ft @
5500 rpm USA
-86-87 D16A1 1G - DA 1590 9.5 : 1 113 @
6250 rpm 99 lb/ft @
5500 rpm USA
-86-89 ZC 1G - DA 1590 9.6 : 1 129 @
6800 rpm 106 lb/ft @
5700 rpm Japan
there you go dude
Old Dec 2, 2006 | 08:00 PM
Boots's Avatar
Default Re: specs on gsr (bigbucksGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbucksGSR &raquo;</TD></TR><TR><TD CLASS="quote">Integra
CC's Compression
Ratio Horse
97-98
7500 rpm USA
6200 rpm USA
-94-00 Ls / Rs
5200 rpm USA
6200 rpm Japan
7500 rpm Japan
5000 rpm USA
5200 rpm USA
7000 rpm USA
5500 rpm Japan
-90-93 X Si
7000 rpm Japan
5500 rpm USA
6250 rpm 99 lb/ft @
5500 rpm USA
5700 rpm Japan
there you go dude </TD></TR></TABLE>
uh dude...he totally meant torque specs like he said in his post
Old Dec 2, 2006 | 11:36 PM
he asked for all specs and he recieved all specs
Old Dec 3, 2006 | 01:27 AM
vladd's Avatar
Default Re: (bigbucksGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbucksGSR &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know any websites that has every spec i would need to know about my motor. when i say specs, i mean torque specs and pretty much every little detail i need to known about the motor and how to rebuild it properly.
he asked for all specs and he recieved all specs</TD></TR></TABLE>
i think by 'torque specs' the op meant how much torque to apply to nuts and bolts, not much torque the engine makes. after all, he's talking about rebuilding the engine.
Old Dec 3, 2006 | 01:29 AM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jikespingleton &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know any websites that has every spec i would need to know about my motor. when i say specs, i mean torque specs and pretty much every little detail i need to known about the motor and how to rebuild it properly.</TD></TR></TABLE>
do a search for the factory service manual here. it has a lot of the torque specs for the engine.
Old Dec 3, 2006 | 02:12 AM
NH538DB8's Avatar
You need a HELMS manual. It is the factory service manual and contains all the information you could possilby need and then some. They are about 65 bucks from helmsinc.com or if you look around you can probably find a PDF copy roaming the internet. Do NOT substitute with a chiltons or haynes, compared to the helms it would be like asking a 4 year old about the torque specs.
Old Dec 3, 2006 | 09:38 AM
cool, thanks guys.
r95eclipsers-t
Sep 25, 2011 05:46 AM
Dkahn18
Feb 21, 2009 07:19 PM
Dkahn18
Feb 15, 2009 08:35 PM
LS94tegra
Feb 3, 2008 05:06 PM
MidoriEK4
Dec 15, 2002 10:26 AM
