225/40/18's?
Old May 9, 2002 | 11:37 PM
98Psi ITR's Avatar
Default 225/40/18's?
How will they fit? Any pics?
Old May 9, 2002 | 11:43 PM
poison's Avatar
Default Re: 225/40/18's? (98Psi ITR)
damnnn that's a huge *** tire/rims if u ask me.
and how will they fit, why would u put 'em on a type r?
i think 17 should be the biggest to put on any honda car except nsx or s2000
Old May 9, 2002 | 11:55 PM
Misfit's Avatar
Default Re: 225/40/18's? (poison)
clearance for suuuuuper big brakes.
i really have no idea.
Old May 10, 2002 | 12:04 AM
98Psi ITR's Avatar
why not, rims weigh only 16lb's each.
Old May 10, 2002 | 05:57 AM
nsxtcjr's Avatar
New User
why not
Because the outer diameter is 7.0 percent larger than stock. You WILL feel the difference in poorer acceleration.
Old May 10, 2002 | 06:00 AM
sgT's Avatar
sgT
last i checked, they wont.
most i see are 225/35/18
Old May 10, 2002 | 06:03 AM
GM2000ITR's Avatar
New User
Default Re: 225/40/18's? (sgT)
Agreed!....the largest you will be able to fit (w/out any modifications obviously) would be a 215/35/18. I had this size once .....TOO DAMN HARD!, but good luck!
[Modified by GM2000ITR, 3:04 PM 5/10/2002]
Old May 10, 2002 | 08:49 AM
98Psi ITR's Avatar
Default Re: 225/40/18's? (GM2000ITR)
here's the car now.
Old May 10, 2002 | 08:57 AM
Dropspeed's Avatar
I ran 18s about 3-4 years back on my 1st and 2nd tegs. when I was into the BLIng BLing 215/35/18, They fit and rub.
Mattj
Old May 10, 2002 | 09:01 AM
98Psi ITR's Avatar
Default Re: 225/40/18's? (Dropspeed)
215 is ok, but i don't want to bang these guys with 35's if possible
Old May 10, 2002 | 09:05 AM
sgT's Avatar
sgT
put your ride height back to stock and they MIGHT fit
Old May 10, 2002 | 09:06 AM
98Psi ITR's Avatar
np
Old May 10, 2002 | 09:22 AM
i 4's Avatar
i 4
man the car looks good the way its sitting, i wouldnt put 18s in there( too big, and will probably look cheezy), if you really wanna change wheels get 16x7s with gripy tires..
Hoosierboy
Nov 27, 2013 02:00 PM
92redprelude
Jul 17, 2010 09:15 AM
sasjod
Sep 10, 2007 01:04 PM
cooldudeness
May 8, 2007 02:14 AM
