antenna nut wrench substitute?
Old Dec 2, 2006 | 02:30 PM
MK Ultra's Avatar
Default antenna nut wrench substitute?
I was hoping to replace my antenna and motor assembly this weekend, but forgot that the dealership parts counter closes at 4 p.m. today. Does anyone here know of a trick to remove the antenna nut without using the factory tool?
Old Dec 2, 2006 | 02:43 PM
KOALA YUMMIES's Avatar
Default Re: antenna nut wrench substitute? (MK Ultra)
Use a flathead screwdriver and a small hammer, mask the area around the antenna with a couple layers of masking tape in case you slip. Use the flathead against the slots on the antenna nut and lightly tap the end with the hammer to rotate it off. It might take some time but be gentle so you dont knick the nut or slip and hit the body of the car.
Old Dec 2, 2006 | 03:08 PM
Jon D's Avatar
Default Re: antenna nut wrench substitute? (KOALA YUMMIES)
er'yup.... Koala knows whats up
<----just swapped motors the other week.
Old Dec 2, 2006 | 03:15 PM
Spids5's Avatar
Don't judge or question
Default Re: antenna nut wrench substitute? (Jon D)
Go to home depot and pick up some snap ring pliers for $10. They will do the job and are a lot better than the screw driver and hammer method. I've done it with a screw driver and I almost slipped and scratched my car.
Old Dec 2, 2006 | 03:40 PM
Default Re: antenna nut wrench substitute? (Spids5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spids5 &raquo;</TD></TR><TR><TD CLASS="quote">I've done it with a screw driver and I almost slipped and scratched my car.</TD></TR></TABLE>
Thats why you mask off the body and dont go crazy hitting the screwdriver...
Old Dec 2, 2006 | 03:45 PM
Spids5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">
Thats why you mask off the body and dont go crazy hitting the screwdriver...</TD></TR></TABLE>
It was well protected but it was rusted so I had to hit it a little harder. It slipped but I barely missed the car.
Old Dec 2, 2006 | 03:47 PM
GO-FIGHT-KILL's Avatar
The screwdriver method works great... But like previously stated, watch the paint.
Do what I did though... S2000 antenna.
PM RStoR, he makes the installation kits.
Old Dec 2, 2006 | 05:17 PM
Wannabe JDM's Avatar
Default Re: (GO-FIGHT-KILL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">
werd. thats what i did.
Old Dec 2, 2006 | 08:55 PM
MK Ultra's Avatar
Thanks.
I thought about using a hammer and flathead, but I don't want to put the new one on that way. I may try the snap ring pliers, or I may just put it off until next week.
As for the antenna, I've already got the new OEM assembly. Don't really like the S2K antenna on Integras.
Old Dec 3, 2006 | 02:29 AM
MatrixShark's Avatar
I used a pair of small needle nose pliers that have a right angle bend at the end. The points of the pliers fit right into the holes. That method worked pretty good for me.
Old Dec 3, 2006 | 10:13 AM
mugenracer's Avatar
Default Re: (MatrixShark)
I used regular needle nose pliers, worked perfectly, just take your time and as koala said, mask off the paint around the antenna.
Old Dec 3, 2006 | 01:45 PM
pyitrboy's Avatar
Why not just use some slip joint pliers and a piece of cloth so you don't sctatch the chrome lock nut.
Old Dec 4, 2006 | 09:03 PM
MK Ultra's Avatar
Default Re: antenna nut wrench substitute? (pyitrboy)
I mainly want to avoid binding the new antenna. If the torque specs aren't right on the antenna nut, you can damage the new motor.
Anyway, it's all moot now, since I've got the proper tool.
Old Dec 5, 2006 | 04:52 AM
oldbeefcake's Avatar
Do they make a cap for the hole if you don't want the antenna? I thought I saw it once.
Old Dec 5, 2006 | 06:44 AM
BudMan's Avatar
Default Re: antenna nut wrench substitute? (oldbeefcake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldbeefcake &raquo;</TD></TR><TR><TD CLASS="quote">Do they make a cap for the hole if you don't want the antenna? I thought I saw it once.</TD></TR></TABLE>
ebay is your friend.
Old Dec 5, 2006 | 06:57 AM
RTW DC2R's Avatar
are you swapping the motor out because its bad? or is there some kinda of aftermarket motor that doesnt raise the antenna 30ft high? lol
S2K antenna was my first mod w00t!
Old Dec 5, 2006 | 07:09 AM
walker111's Avatar
Default Re: (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">are you swapping the motor out because its bad? or is there some kinda of aftermarket motor that doesnt raise the antenna 30ft high? lol
S2K antenna was my first mod w00t!</TD></TR></TABLE>
The switch that turns the antenna off so that its not up when the radio is on was high on my list!
Old Dec 5, 2006 | 07:36 AM
Doespike's Avatar
Default Re: (walker111)
yeah, why Honda didn't integrate the antennae into the glass like on the sedans is beyond me....
Old Dec 5, 2006 | 11:14 PM
MK Ultra's Avatar
The motor and mast are both fried. I've got a new OEM setup to replace them.
An aftermarket motor with a shorter mast would be cool, but I like the idea of having it in the backlight best. If a replacement glass company offered new backlights with antennas in them, I'd have gotten one the last time my car was in the body shop and had OEM the antenna shaved. I still think that would look clean, especially if the backlight were available with the wiper-delete.
Oh, and my stereo only extends the antenna when the tuner is selected, which I thought was pretty cool.
Old Dec 6, 2006 | 08:17 AM
jomama's Avatar
Default Re: (Doespike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doespike &raquo;</TD></TR><TR><TD CLASS="quote">yeah, why Honda didn't integrate the antennae into the glass like on the sedans is beyond me.... </TD></TR></TABLE>
(db8) sedans have telescoping antennas as well. i think they look cool... it's like you're driving a remote control car
sobey
Mar 4, 2009 07:06 PM
Duff Beer Man
Jul 17, 2006 05:49 PM
RUBZERK
Sep 11, 2004 08:09 PM
Yell00ITR
Apr 11, 2004 09:50 PM
97ITR
Nov 5, 2003 07:05 PM
