Suspension & Brakes Theory, alignment, spring rates....
sway bar
Old Dec 2, 2006 | 11:39 AM
Boots's Avatar
Default sway bar
wondering is a jdm 23mm itr sway bar will fit my 94 ls? if anyone knows that would greatly appreciated
Old Dec 2, 2006 | 05:26 PM
B16B_coupe's Avatar
HRD PKR
Default Re: sway bar (boots)
it should
Old Dec 3, 2006 | 12:51 PM
BlueIntegraBoy's Avatar
Yes, it will.
http://hybrid2.honda-perf.org/tech/ITRon5G.html
Or you can buy ITR brackets, and not worry about what they did at the end.
Old Dec 3, 2006 | 02:35 PM
lateral G's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boots &raquo;</TD></TR><TR><TD CLASS="quote">wondering is a jdm 23mm itr sway bar will fit my 94 ls? if anyone knows that would greatly appreciated</TD></TR></TABLE>
yes, you just need to reinforce the subframe,
BSQ and Beaks both make reinforcement kits, of if you come across a Comptech tie bar for cheap you can use that for the reinforcement.
Old Dec 4, 2006 | 07:36 AM
Boots's Avatar
Default Re: sway bar (lateral G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lateral G &raquo;</TD></TR><TR><TD CLASS="quote">yes, you just need to reinforce the subframe,
BSQ and Beaks both make reinforcement kits, of if you come across a Comptech tie bar for cheap you can use that for the reinforcement. </TD></TR></TABLE>
thanks and i already have an ASR subframe brace, i just need a bigger sway bar
aemintgsr
Jan 19, 2008 05:09 PM
94IntegraLs04
Jan 16, 2006 06:49 PM
egtype-r
Jan 10, 2006 08:24 AM
RRRex
13
Dec 12, 2003 08:21 PM
ITR Demon
Aug 1, 2003 10:35 AM
