3 Tranny Questions
Old Dec 2, 2006 | 09:09 AM
7rrivera7's Avatar
Default 3 Tranny Questions
1) I have a Y1 cable trans with a 4.2 final which is not good for all motor. What can I do to improve it short of replacement?
2) I have two YS1 440 cable trannys. How can I tell if they are a USDM 90-93 Integra or from a 92-93 GSR?
3) On the YS1 trannys, which is better for acceleration (with the FD staying the same), lower or higher numbered gear ratios?
Thanks!
Old Dec 2, 2006 | 09:49 AM
slofu's Avatar
Default Re: 3 Tranny Questions (7rrivera7)
1) swap for a 4.4 fd- trans swap is easier, though.
2) open the case (it's not that hard) and count the teeth on the gears. the first gear ratio of the 92-3 ys1 trans from the b17 gsr is 3.307; the 90-93 ls trans has a 3.230 first gear ratio.
3) gears with closer numerical ratios are generally (for us) better for acceleration.
Old Dec 2, 2006 | 10:47 AM
7rrivera7's Avatar
Default Re: 3 Tranny Questions (slofu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slofu &raquo;</TD></TR><TR><TD CLASS="quote">
3) gears with closer numerical ratios are generally (for us) better for acceleration.</TD></TR></TABLE>
2) count the teeth and tehn what - divide by the # of teeth on the FD or divide the FD by the number of teeth on the gear?
3) Ok but if the number is higher is the tranny quicker or the opposite?
Old Dec 2, 2006 | 10:56 AM
Boots's Avatar
the more teeth, the faster the acceleration
Old Dec 2, 2006 | 02:30 PM
slofu's Avatar
Default Re: 3 Tranny Questions (boots)
divide the # teeth on output/counter shaft by # on input shaft, e.g. 42/13=3.230 for 1st gear.
short answer: use the b17a gsr ys1 trans if you have it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boots &raquo;</TD></TR><TR><TD CLASS="quote">the more teeth, the faster the acceleration</TD></TR></TABLE>
not necessarily so. each ratio depends on the # teeth on 2 gears. both the 4.78 and 4.4 fd have 81 teeth total (main+counter), but for any given gear with the same ratio (between 2 trannies), the trans with 4.78:1 fd will yield greater tq by multiplication. you want the right amount. for most NA B series engines 4.78 FD &gt; 4.4, and for most all of our practical purposes closer gearing &gt; longer.
ys1civicsi
May 14, 2007 06:46 AM
ys1civicsi
May 9, 2007 04:08 PM
ys1civicsi
May 9, 2007 04:00 PM
ys1civicsi
May 9, 2007 01:20 PM
