FS: JE 84.5mm pistons and Crane stage 3 cams for B-Series
These parts are left over my an engine I built a little while ago. I changed the setup, so these are what's left over. The parts have about 4,000KM on them, so they're all in excelent shape.
JE 11.5:1 compression pistons for B20 (84.5mm). The valve reliefs are pretty deep so no clearance problems with a VTEC head and the agressive cams I was using. $300
Crane stage 3 cams, B-series VTEC. These are fairly aggressive on the VTEC lobes and will require upgraded springs and retainers. The low lobes are close the ITR specs, so they're still very streetable. $300
http://www.cranecams.com/?show...-0014
I'll sell it all together for $500
Will consider for the following:
-Low compression, 81mm pistons for a LS block
-Clean B series VTEC head.
Modified by freakin at 9:57 AM 12/18/2006
Modified by freakin at 3:24 PM 1/1/2007
Price change + Pics. Email me if you're interested, matteakin(at)shaw(dot)ca. I'm not on this site much anymore.
Here are the pistons when they were new:
Here they are when I took them out. They've been cleaned since, but I haven't had a chance to take better pics.
Here are the cams after I took them out:
I've decided to include the rods as well and I have no need for the B18 parts anymore. I'm just going to boost my B16 instead. They're Eagle H-beams, and pretty much bulletproof. They'll fit any LS bottom end (B18A, B18B, B20).
The rods are going to be $400 for the set and I'll work out a deal with you if you want the pistons with them.
Pony_Fed95
Sep 12, 2005 07:09 PM
majormaster01
11
Feb 4, 2005 10:31 AM
Mr. Samurai
14
Jul 3, 2004 03:47 PM
