h23a1
Here are all of the specs on an H23a1
H23A1
The H23A1 was an enlarged version of the F22B, designed for the North American market version of the 1992–1996 Honda Prelude Si.
Specifications
Bore × Stroke: 87.0 × 95.0 mm
Displacement: 2258 cc (138 cu. in.)
Valve Configuration: DOHC, 16 valves
Type: In-line 4 cylinder, aluminum block and head
Compression ratio: 9.8:1
Max power: 160 hp (119 kW)
Max torque: 163 ft·lbf (207 Nm)
Redline: 6500 rpm
Engine Control System: Honda Systems PGM-FI with port fuel injection
Valve Gear: belt-driven dual overhead cams, 4 valves per cylinder
Engine Oil Capacity w/ Filter: 4.5 Liters
-Shane
H23A1
Specifications
Redline: 6500 rpm
-Shane
