humming
I installed a type r lsd almost 2 months ago and a few days ago whenever I start from i stand still with the wheel far right/left i get a hum for about at the initial movement; but this does not happen when the wheels are straight...LSD have anything to do with this? Or wheel bearings??
aww... snapped... pretty sure someone going to need a wheel bearing replacement pretty soon... anyways that was only a thought.. does it get louder as you get faster??? if so, yep it the wheel bearing...
Your saying that while at a stop you turn the wheel and their is a hum or is it when you are moving. Most of the time you won't here a hum from the wheel unless you are moving. If it happens when you turn left it is most likely the left bearing and vice versa.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinai »</TD></TR><TR><TD CLASS="quote">Your saying that while at a stop you turn the wheel and their is a hum or is it when you are moving. Most of the time you won't here a hum from the wheel unless you are moving. If it happens when you turn left it is most likely the left bearing and vice versa.</TD></TR></TABLE>
I hear it when I turn left and sometimes right when moving from a stop
Honestly just sounds like your p/s pump is struggling a bit. Normally when the bearing goes out you hear it faintly at first at low speeds then it hums louder and louder.
09egkid
Aug 6, 2010 02:54 PM
