HELP; misfire on all four cylinder
I keep getting a check engine light stating that I'm misfiring on all four cylinders. My car drives fine though with no sign of it. I have an MSD 6al and SS blaster coil. I called MSD and asked if maybe I needed a tach adapter but the guy said it wasn't necessary. What are possible problems. I thought it could be ECU related or that maybe the plug wires I'm using could be interfering with it. Has this happened to anyone else?
Thanks for the response. I was thinking it might not be the coil because I just got it about a month ago after my blaster 2 had gone bad. I'm going to check out the plugs though.
i got msd on my ek and i got a misfire on cylinder 1 and 3...i thought it was the plugs or a bad connection then i checked resistance at the wires and it was very high....so i just repalced my wires then it was all g from there... check out the resistnace...its a shot...kdens
HatchBlakKidd
Jun 30, 2011 09:29 AM
JDM_EK4_Coupe
Apr 17, 2007 08:25 AM
CivicSiRracer69
Nov 27, 2004 12:30 PM
