oil leak
Old Dec 1, 2006 | 06:49 AM
lucyh23's Avatar
Default oil leak
I recently built my h23. I put all new gaskets, type s pistons, port and polished head and intake manifold etc. Anyways i have oil coming from my header. where my header meets the head its spitting oil where the header gasket is. i know the header gasket is not made to prevent oil from coming out so why in the hell is there oil even passing that direction. keep in mind that i had all the seals and gaskets replaced. if someone has an idea what might be the problem please help me out.
lucyh23
Old Dec 1, 2006 | 06:52 AM
PrecisionH23a's Avatar
Default Re: oil leak (lucyh23)
Did you put the headgasket on upside down?
Old Dec 1, 2006 | 11:10 AM
MyLilCivic's Avatar
Default Re: oil leak (PrecisionH23a)
Very true my buddie put his head gasket up side down and wow was oil pooring out that thing make sure the tab that hangs out on the head gasket is on the right side, if you were looking at your car with the hood poped is on the left front side. But that was on his b20 Vtec so idk if the head gaskets are diff with there being a tab or not
Cameronphelan
Honda Civic (2001 - 2005)
May 29, 2015 10:23 AM
brandonEM1
Apr 10, 2009 05:01 AM
joetho
Jan 10, 2008 03:19 PM
ALL MOTOR DA
May 1, 2006 02:12 PM
spender1326
Jun 24, 2005 06:41 PM
