TWM 52mm on stock EG H22?
Old Dec 1, 2006 | 05:09 AM
Pippen_001's Avatar
Default TWM 52mm on stock EG H22?
Hi guys.
I want your opinion on fitting a 52mm TWM ITB on a stock H22 block in a EG body, hondata tuned. Would there be runner length problems since it is a EG body? And is it really a good idea or not?
Old Dec 1, 2006 | 08:10 AM
doood's Avatar
been there done that
Default Re: TWM 52mm on stock EG H22? (Pippen_001)
not the first thing i would do to a stock engine
Old Dec 1, 2006 | 08:11 AM
Boots's Avatar
Default Re: TWM 52mm on stock EG H22? (that one doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that one doood &raquo;</TD></TR><TR><TD CLASS="quote">not the first thing i would do to a stock engine</TD></TR></TABLE>
yea its more like the last thing you should do
Old Dec 1, 2006 | 08:38 AM
98vtec's Avatar
moderator emeritus
Default Re: TWM 52mm on stock EG H22? (boots)
if the throttles were smaller and the runners were longer then it would be ok.
Old Dec 1, 2006 | 08:52 AM
BEAVERTOOTH's Avatar
Default Re: TWM 52mm on stock EG H22? (B.Rabbit)
There fine to run on a stock more they well help the motor breath better too. Trust me I have some on a stock h22 crx.
Old Dec 1, 2006 | 08:57 AM
98vtec's Avatar
moderator emeritus
Default Re: TWM 52mm on stock EG H22? (BEAVERTOOTH)
have a dyno graph?
Old Dec 1, 2006 | 09:00 AM
Boots's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BEAVERTOOTH &raquo;</TD></TR><TR><TD CLASS="quote"> There fine to run on a stock more they well help the motor breath better too. Trust me I have some on a stock h22 crx.</TD></TR></TABLE>
this is true but they are not going to breathe better if the stock exhaust manifold and exhaust are suffocating it...also headwork is something i would highly recommend to get it to work at its peak...putting ITB's on it and calling it a day is really not going to net the horsepoewer like it would if the motor was setup for them
Old Dec 1, 2006 | 09:10 AM
GetawayInMoscow's Avatar
Try it and let us know. I'm sure if you tune it you could probably get some good gains!
Old Dec 1, 2006 | 03:12 PM
Pippen_001's Avatar
Well i have a 2.5" exhaust already and am planning on a RMF or SMSP header. I do know that a smaller diameter tb like 48mm would be better off on a stock engine, however i am planning on p&p with jun3's. on the long run stroking it on a 12.5 to 13 cr.
My point/ question is. paying for a skunk2 im, 70mm tb, fuel rail and fpr, would i be better off with the twm52mm for a couple of bucks extra?
http://www.pocketrocketsracing....html
1500 dollars with rail and fpr. I live in europe and that will be more like 1200 for me.
Old Dec 1, 2006 | 09:25 PM
Boots's Avatar
Default Re: (Pippen_001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pippen_001 &raquo;</TD></TR><TR><TD CLASS="quote">Well i have a 2.5" exhaust already and am planning on a RMF or SMSP header. I do know that a smaller diameter tb like 48mm would be better off on a stock engine, however i am planning on p&p with jun3's. on the long run stroking it on a 12.5 to 13 cr.
1500 dollars with rail and fpr. I live in europe and that will be more like 1200 for me.</TD></TR></TABLE>
id build the head and get that bitch breathing better before the ITB's but thats just me
ktmclay
Jun 12, 2009 04:08 PM
SEQEUL
Jan 10, 2005 10:38 AM
soon2b
Dec 28, 2004 03:08 PM
H O N D A
Feb 29, 2004 06:30 PM
Rukusmasta2
Aug 27, 2003 11:09 PM
