Post Your DIY Door Panel Inserts!!!
Old Nov 30, 2006 | 10:08 PM
Ransom's Avatar
Default Post Your DIY Door Panel Inserts!!!
Im thinking about doing my door panel inserts with red or black suede. Post pics of your inserts and the type of material you used.
Old Nov 30, 2006 | 10:16 PM
waddy41's Avatar
black suede w/ red stitch
Old Nov 30, 2006 | 10:17 PM
Ransom's Avatar
Default Re: (waddy41)
that would be the ****, but i cant sew
Old Nov 30, 2006 | 11:06 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: (LudeSH)
yes its green camo!! not urban camo
Old Nov 30, 2006 | 11:32 PM
drevinder's Avatar
Default Re: (spock_rocker)
nice brass knuckel....those are illegal
Old Nov 30, 2006 | 11:41 PM
HAUS's Avatar
^^^ so is whats in my system and my pockets everytime i drive, hahaha
Old Nov 30, 2006 | 11:53 PM
SamRi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker &raquo;</TD></TR><TR><TD CLASS="quote">
yes its green camo!! not urban camo </TD></TR></TABLE>
i think it would have look better in
A:urban camo
B: Marie DDCU camo (desert) Or FDCU camo (forest)
C:Army ACU Camo (I were this one everyday)
Old Dec 1, 2006 | 12:05 AM
Default Re: (SamRi)
i hate urban camo.. i was just going w/ the typical camo.. and the only kind the fabric store had!
Old Dec 1, 2006 | 12:52 AM
alaskan_teg00's Avatar
I definetly plan on doing some custom work with my door panels. Sometime over the winter it should be done.
Old Dec 1, 2006 | 03:26 AM
acura_el2000's Avatar
any colour pics of that then?
Old Dec 1, 2006 | 04:38 AM
fventura03's Avatar
in for more, is there a DIY. is it hard?
i want to do black cloth/suede. something that looks OEM.
Old Dec 1, 2006 | 05:44 AM
ZacCarter's Avatar
Old Dec 1, 2006 | 05:50 AM
JDM knowledge's Avatar
Default Re: (fventura03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 &raquo;</TD></TR><TR><TD CLASS="quote">in for more, is there a DIY. is it hard?
i want to do black cloth/suede. something that looks OEM.</TD></TR></TABLE>
im guessing you just cut the fabric. Take off those molded screws no teh back of the panel. Some fabric glue to the back of the fabric. Walla walla bing bang your done.
Old Dec 1, 2006 | 06:03 AM
fventura03's Avatar
yeah thats what i thought. gotta try this one day...
DevilSolSi's Avatar
Default Re: (JDM knowledge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM knowledge &raquo;</TD></TR><TR><TD CLASS="quote">
im guessing you just cut the fabric. Take off those molded screws no teh back of the panel. Some fabric glue to the back of the fabric. Walla walla bing bang your done.</TD></TR></TABLE>
The door panel is 2 pieces. There are these plastic screws that hold the 2 pieces together, but it looks like they are melted on. I put a screwdriver in between the 2 pieces and just broke the screws. I used red vinyl, and I just covered it over the existing material. Then used some self tapping screws to put the pieces back together. All in all it is pretty easy. I will post pics of my old Del Sol door panels later.
Here's a tip, use a heat gun or blow dryer to stretch the fabric when you are covering the panels so that it doesn't bubble or wrinkle.
Old Dec 1, 2006 | 06:05 AM
ff terror's Avatar
too old for school
I want to do this to my EP's door panels...
1. How do you guys separate the insert from the door panel?
2. Or do you just go over it while the insert is still attached to the door panel?
Personally, I'd rather remove the insert from the door panel so that I can wrap the fabric all the way around it... but please give me some tips!!
Old Dec 1, 2006 | 06:07 AM
vtec4lyfe's Avatar
Please nobody post their pictures of their shitty wrinkled door panels. If you actually going to do it be sure to stretch it correctly and im sure you would benefit from using a type of spray adheisive.
Old Dec 1, 2006 | 06:18 AM
JDM_EM1's Avatar
diy door panels and armrest...
Old Dec 1, 2006 | 06:22 AM
njn63's Avatar
not mine but a quick picture i snapped at Formula D Chicago:
Old Dec 1, 2006 | 06:50 AM
Default Re: (ff terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ff terror &raquo;</TD></TR><TR><TD CLASS="quote">I want to do this to my EP's door panels...
Personally, I'd rather remove the insert from the door panel so that I can wrap the fabric all the way around it... but please give me some tips!!</TD></TR></TABLE>
its 2 pieces. Not sure of the EP ones but i know on others they are molded crews. Or like my S2k they are held with phillips screws. Just use a screw driver and some man strength to knock them loose.
Old Dec 1, 2006 | 09:57 AM
Simple's Avatar
and i thought i was the only one with camo inserts, how silly of me
Old Dec 1, 2006 | 10:12 AM
4doorjdmwhore's Avatar
Default Re: Post Your DIY Door Panel Inserts!!! (LudeSH)
hah I really have been considering this...
Old Dec 1, 2006 | 10:14 AM
777sC's Avatar
i gotta do this on my DA ... my stock ones got some wear marks on them over time
Old Dec 1, 2006 | 10:23 AM
swoyEKr.'s Avatar
Black suede. It's really cheap online for a decent grade. Like 20 bucks a yard at most, which you would only need one yard, two for eg's. Get some 3m upholstery adhesive and get both the martial good and tacky and the insert itself. I like to spray the whole insert that spray portions of the material as I work it down flat around the edges.
Old Dec 1, 2006 | 10:36 AM
J.nguyen's Avatar
Default Re: Post Your DIY Door Panel Inserts!!! (swoyEKr.)
