high pitched noise
Old Nov 30, 2006 | 07:43 PM
soon2bdropped's Avatar
Default high pitched noise
okay i have a 95 honda accord ex sedan 5spd.. okay i notice that if i take off.. like 1st gear..2nd gear.. 3rd gear u can hear a high pitched sound like the car got turbo but is not spooling type of sound... is this normal? it doesn;t do it while idle.. and its not the belts i don't think..
Old Nov 30, 2006 | 07:49 PM
BlUAc's Avatar
Default Re: high pitched noise (soon2bdropped)
how is your drivability shakey may the hub bearings have you worked on it latley t-belt or n-e-thing
Old Dec 1, 2006 | 12:57 PM
Default Re: high pitched noise (BlUAc)
wat?
Old Dec 4, 2006 | 07:42 PM
anybody else?
Old Dec 4, 2006 | 07:46 PM
Krisgh15's Avatar
mmmm do you an amp and subs? I used to have that same sound comming through my speakers, haha my friend would always joke asking if i had turbo. It was the alternator whinning.
Old Dec 4, 2006 | 07:51 PM
Default Re: high pitched noise (Krisgh15)
yes i do.. but i think the sound was there before the subs.. but previous owner had a system.. and come to think of it.. i think it is the alternator whining.. is that a bad thing.. or it means alt might need replacing.. sound turbo.. but when ur in 3rd gear or 4th you dont really hear it..
Old Dec 4, 2006 | 07:53 PM
AJ06's Avatar
Its most likely a grounding issue
I have the alt whine thru my speakers... gotta get it fixed... eventually when I have time.
Old Dec 4, 2006 | 07:57 PM
Default Re: (AJ06)
its not coming thru the speakers.. it coming from the engine itself..... if i get a new alt will that solve the problem? or still persist?
Old Dec 5, 2006 | 09:00 PM
Default Re: (soon2bdropped)
anymore suggestions?
Old Dec 6, 2006 | 08:52 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2bdropped &raquo;</TD></TR><TR><TD CLASS="quote">its not coming thru the speakers.. it coming from the engine itself..... if i get a new alt will that solve the problem? or still persist?</TD></TR></TABLE>How much does it bug you?
A normal alternator makes a spinning/whining noise, but it isn't very loud. If the noise gets louder, it can be the alternator beginning to go bad. It can take a long time
You could wait for it to get louder, then maybe you can replace the alternator in spring instead of now?
Old Dec 6, 2006 | 09:46 PM
Default Re: (JimBlake)
cool so its not a grounding problem?
Old Dec 7, 2006 | 02:56 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2bdropped &raquo;</TD></TR><TR><TD CLASS="quote">cool so its not a grounding problem?</TD></TR></TABLE>Normal alternator sound is pretty quiet. How loud is yours? I can't hear it from here. I was just suggesting a possibility.
You should still check out whether you have any flaky grounds or stuff like that anyway.
KidKavika
Mar 31, 2013 12:25 PM
a2_DC5
Sep 9, 2006 05:44 PM
94ls
Sep 2, 2004 05:11 AM
WRTEG
Mar 5, 2004 09:55 AM
wessieball
Audio / Security / Video
Jan 3, 2004 02:02 PM
