BPi Flow Stack ON AEM COLD AIR INTAKE
Old Nov 30, 2006 | 07:11 PM
Real Ek4's Avatar
Default BPi Flow Stack ON AEM COLD AIR INTAKE
Hello,
I'm interested in buying a BPi FLOW STACK, but I have a question... I own a Honda Civic VTi (Engine B16A2) with a Cold Air Intake AEM 2.75" which is obviously smaller than the BPi FLOW STACK 3", this is the question... Is it worth it to make the investment and buy the FLOW STACK and put them together knowing that one is bigger than the other? Will i lose hp?
» Engine Mod:
1.6 DOHC VTEC B16A2 (stock block)
Hondata Heatshield
CTR Cams
AEM adjustable Cams gear
AEM Cold Air Intake
Apexi N1 4-2-1 Header & exhaust system
Fuel Pressure Gauge Set
JDM ITR Throttle Body 62mm
Thank you in advance,
Real Ek4
Old Nov 30, 2006 | 08:25 PM
gsrious's Avatar
should work fine... i have mines fab'ed up the the stock gsr intake arm.
Old Nov 30, 2006 | 11:11 PM
MikeSarr_GSR's Avatar
Default Re: (gsrious)
BPI to stock GSR intake arm w/6" k&n here also. I was suprised to see
how well it worked. no numbers to display but impressed
Old Dec 1, 2006 | 05:51 AM
Real Ek4's Avatar
Default Re: (MikeSarr_GSR)
Thanks
Old Dec 1, 2006 | 08:21 AM
Mohsin's Avatar
any numbers / dynos of BPi / vel stack on an AEM CAI?
Would be interesting to see the gains if any.
Old Dec 1, 2006 | 08:54 AM
No_Fear's Avatar
i would like also to see results of those 2 together.
Old Dec 1, 2006 | 08:58 AM
stevieteg's Avatar
Default Re: (Mohsin)
i tried to put the bpi stack with the 6" k&n filter on my aem itr cai, It fit on the intake fine, but the filter was too big/hung too low to put the lower splash guard back on. I ended up going with a short ram setup.
You can buy coupling reducers. Search for turbo couplings, they should offer a 3" to 2.75" coupling.
imo a 3" stack on a 2.75" pipe will work fine. i mean it's only a 1/4 of an inch. regardless your not going to notice any major gain or loss with a minor intake mod.
If I were you I'd consider a sri. I didn't want to switch over either, but I'm glad I did. Now I'm not parinoid to drive in the rain
Old Dec 1, 2006 | 11:25 AM
Real Ek4's Avatar
Default Re: (stevieteg)
^^^Thank You Very Much!!!
Old Feb 9, 2007 | 12:00 AM
No_Fear's Avatar
any dyno?
Old Feb 9, 2007 | 05:23 AM
esteen2's Avatar
Default Re: (No_Fear)
http://www.racepartsolutoins.com has a 2.75 to 3.00 reducer, and its pretty cheap
Old Feb 9, 2007 | 06:16 AM
goforbroke's Avatar
MEAT PATTY
Default Re: (S2R Honda)
Their is very good comparsion floating around of a short ram compared to cold air intake with the BPI flow stack.
Old Feb 9, 2007 | 08:27 AM
ESP-net
Guest
Posts: n/a
Default Re: (goforbroke)
Simple reducer 2.75-3"
I noticed a difference with my h22 crx setup...lil quicker throttle response...tiny bit more get up through the power band it seemed...definetly a gain of power not a loss...
My BPI and K&N filter
Old Feb 9, 2007 | 09:53 AM
C1CRX's Avatar
Traffic signal tech
Default Re: (ESP-net)
pic of filter i use on my BPI stack and i noticed a definite increase also.
Old Feb 9, 2007 | 10:49 AM
SteveoBA8's Avatar
Default Re: (C1CRX)
Do it.
Old Feb 22, 2007 | 02:38 AM
BryanPendleton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevieteg &raquo;</TD></TR><TR><TD CLASS="quote">i tried to put the bpi stack with the 6" k&n filter on my aem itr cai, It fit on the intake fine, but the filter was too big/hung too low to put the lower splash guard back on. I ended up going with a short ram setup.
Here's is an alternative filter (more compact and shorter) that worked on this ITR:
http://www.itrca.com/forums/vi...light=
Old Feb 22, 2007 | 02:42 AM
Default Re: BPi Flow Stack ON AEM COLD AIR INTAKE (Real Ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Real Ek4 &raquo;</TD></TR><TR><TD CLASS="quote">Hello,
We noticed a slight gain 1-3whp on my b17 with 2.75" AEM si short ram intake. I flared my intake pipe instead of using a reducer coupling though.
Old Feb 22, 2007 | 02:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke &raquo;</TD></TR><TR><TD CLASS="quote">Their is very good comparsion floating around of a short ram compared to cold air intake with the BPI flow stack. </TD></TR></TABLE>
One of our retailers, HybriDynamics, has run a lot of interesting tests, including a sri to cai test with our stack. We have not published then yet, because we are gearing up for the launch of a new dyno test "database" on our site.
Old Feb 22, 2007 | 06:52 AM
goforbroke's Avatar
MEAT PATTY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BryanPendleton &raquo;</TD></TR><TR><TD CLASS="quote">
One of our retailers, HybriDynamics, has run a lot of interesting tests, including a sri to cai test with our stack. We have not published then yet, because we are gearing up for the launch of a new dyno test "database" on our site. </TD></TR></TABLE>
Their is a guy on here, who multiple test with short ram and cold air intake. A bunch of different varation test comparing the two. I can't find the thread though. I believe it was on a stock K20. It was in the integra forum I believe, my memory sucks.
Old May 7, 2007 | 10:54 PM
9WON4's Avatar
Default Re: (BryanPendleton)
http://www.itrca.com/forums/vi...light=</TD></TR></TABLE>
O....do you have the part number for that filter I'm going to be purchasing your stack and that filter looks perfect
Old May 8, 2007 | 08:03 AM
Default Re: (9WON4)
RF-1009
RU-4600
RP-4600
RT-4600
These are all 4" height, but the RF-1009 tapers to a 5" OD top where as the others taper to a 4.5" OD top
RF has chrome top, RU is rubber top, RT is titanium top, RP is Carbon Fiber top.
Old May 8, 2007 | 08:14 AM
9WON4's Avatar
so in that thread is just an "illusion" that the filter looks so compact
Old May 8, 2007 | 10:53 AM
Default Re: (9WON4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9WON4 &raquo;</TD></TR><TR><TD CLASS="quote">so in that thread is just an "illusion" that the filter looks so compact</TD></TR></TABLE>
I am not following you, what are you asking?. "compact" is a relative term.
Old May 8, 2007 | 01:28 PM
9WON4's Avatar
Sorry on the pic on the thread, that filter "looks": to be about half of the length of the other ones that work with your stack.
is that the case or is just the pic that makes it look that way
hope I cleared it up.....a.k.a for my car the shorter the filter is (in overall length) the better
Old May 8, 2007 | 06:42 PM
Default Re: (9WON4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9WON4 &raquo;</TD></TR><TR><TD CLASS="quote">Sorry on the pic on the thread, that filter "looks": to be about half of the length of the other ones that work with your stack.
hope I cleared it up.....a.k.a for my car the shorter the filter is (in overall length) the better</TD></TR></TABLE>
Yes it is more compact. It 2" shorter in length, when compared to the RF-1048
Old May 8, 2007 | 06:57 PM
9WON4's Avatar
Yes it is more compact. It 2" shorter in length, when compared to the RF-1048</TD></TR></TABLE>
sorry for not being clear in my initial question. So next question what is the part number for that smaller filter. thanks for the help
