z10 tracktion bars???
Old May 9, 2002 | 07:25 PM
lazyguy's Avatar
Default z10 tracktion bars???
are these bars worth the money? does anyone have any experience theyd like to share about them?
Old May 9, 2002 | 07:35 PM
Dropspeed's Avatar
Default Re: z10 tracktion bars??? (b18cURmama)
I have the Z10 kit on my ITR, I love it, but don't feel like typing, Do a search and type Z10, I just checked and pulled up at least ten posts on them.
Mattj
Old May 9, 2002 | 07:41 PM
lazyguy's Avatar
Default Re: z10 tracktion bars??? (Dropspeed)
thanks bro
Old May 9, 2002 | 07:45 PM
Dropspeed's Avatar
This is the last one I participated in https://honda-tech.com/zerothread?id=172247
Mattj
Old May 9, 2002 | 07:56 PM
TodaSi's Avatar
Mattj
Matt, didn't you participate in every Z10 post
Old May 9, 2002 | 07:59 PM
Dropspeed's Avatar
Default Re: z10 tracktion bars??? (TodaSi)
Matt, didn't you participate in every Z10 post [/QUOTE]
Yeah, And I still haven't seen a check from Z-10. There product worked very well for me so Z10 still gets a
Mattj
Old May 9, 2002 | 08:45 PM
AssPenny's Avatar
me too big
Craig - Who is still fine tuning them
Old May 10, 2002 | 04:19 AM
Lip's Avatar
Lip
Default Re: z10 tracktion bars??? (AssPenny)
and of course..me to.
just check the photo in the advertisment at the top of the pagen when z10 pops up. recognize it
Old May 10, 2002 | 05:37 AM
CHEETAH's Avatar
yes, I've seen 60' times come down a matter of 2/10ths in some cases. In street trimmed cars, stock front street tires are planted harder on the ground as the car tries to lift the bars counteract 2 times over. Too hard of an adjustment and something will give, i.e. I've seen axles snap if not adjusted correctly. Need to leave play. Also, tops off great with poly urethane bushings.
Please feel free to email Rob or Jimmy or even Chrissi at Z10, they're all more than happy to help out.
Greg
Old May 10, 2002 | 05:43 AM
Anderson's Avatar
Default Re: z10 tracktion bars??? (CHEETAH)
nice
Old May 10, 2002 | 06:00 AM
sneakychaos's Avatar
Default Re: z10 tracktion bars??? (Anderson)
I've heard people are having problems placing orders for the kits for the DC2's... *shrugs* I haven't tried, although I really should.
Old May 10, 2002 | 06:21 AM
Lip's Avatar
Lip
Default Re: z10 tracktion bars??? (trooth)
its easy. contact them and tell them jeff and greg sent you
Old May 10, 2002 | 06:29 AM
Big Teggie's Avatar
Default Re: z10 tracktion bars??? (Lip)
What do they cost?
Old May 10, 2002 | 06:30 AM
Black R's Avatar
25 Year Member
Greg
I've been considering these for some time, but am wondering if they're almost like a rubber chicken:
They reduce or eliminate wheel hop, but does that translate into better 60 ft or 1/4 times? Dropspeed says no, while Greg says yes.....
What about better lap times on the road course or autox, because the car has more traction on corner exit? I *think* Dropspeed is saying yes.....
It seems to me, that the z10 bars all but eliminate wheel hop... but does this in fact cause wheelspin instead, and no better times?
I'd like to know b/c z10 bars are on my list of mods to come.....
Old May 10, 2002 | 06:38 AM
Lip's Avatar
Lip
Default Re: z10 tracktion bars??? (Black R)
no. it doesn't cause wheelspin. you have to remember that its part of a system. if your tires blow....your launch blows. if your shocks are blown...your still gonna get some lift off the pavement. i'll locate the article that was writen on the z10 for you in roadracing. http://hybrid2.honda-perf.org/tech/z10.html
i had difficulties with my z10's early on...but it was because they weren't adjusted properly. i found the best way to be.....lift whole front end off the ground. adjust rods so that you can still turn them by hand pretty easily. when car is set on the ground they have slight preload. i net 1.71-1.75 60' tims consistantly
Old May 10, 2002 | 06:42 AM
CHEETAH's Avatar
actually, some people claim they still have wheelhop but I have never experienced that, and I have noticed considerable reduction in 60' and et
With respect to the wheel hop some people see, the bars are generally not adjusted, hey are just bolted on and thats it so of course they would not get the true effectiveness of the traction system. On street cars, I've adjusted them and people really love the response, but Jimmy knows the best adjustment points.
But the answer is yes, they help plant the car and reduce wheel hop and increase acceleration.
Greg
Old May 10, 2002 | 06:46 AM
TRuST's Avatar
I eliminated alot of my wheel hop with the Z10 bars, but I would rather have wheelspin which I think is more predictable than wheel hop and wheelspin.
I didn't notice any ground breaking 60' times, but I did notice that my 60' time were alot more consistant witht he Z10s. I don't auto-x much but I did notice that the Z10 made a difference in cornering. I felt like thewheels were more planted than before.
I agree with Greg, I over tighten my Z10s and it snapped my axle in half. But Once, I correctly adjusted them I haven't had a problem since.
sgT's Avatar
sgT
I had no wheel hop before or after i installed the z-10 bars.
I WAS running 1.7 60' before and 2.0 after though. I adjusted the bars every which
way and even went so far as to realign the car after adjustment. no change.
no traction. Needless to say, they are gone.
Old May 10, 2002 | 07:15 AM
R134's Avatar
So do you preload them with both wheels off the ground? How many turns?
Old May 10, 2002 | 07:22 AM
Dropspeed's Avatar
Default Re: z10 tracktion bars??? (sgT)
I was at the dragstrip the week before and the week after the Z-10 bars where installed. It is correct I was running 2.0 60 foots on a 17 inch street tire and was able to continue, But it was MUCH easier to launch without drama/wheelhop. Evertime I shifted into 2nd at the dragstrip More wheelhop. In my case The Z10 BAr eliminated all of the wheel hop and made it easier to drive, but my 60ft stayed the same, on street tires. If I switched to slicks It might be different
On a road course, I just can't describe how fast the car can accelerates away from a corner because of the added traction. Hopefully I'll show people at the EXPO
The car just feels so planted with out any I'll affects.
My car is not set-up for Drag-racing its just something I enjoy doing. SO with the proper set-up I would yield better 60fts. The car has Apex-i N-1s, 2 degrees of negative camber front and rear and has the toe out in the front.
Mattj
Old May 10, 2002 | 07:25 AM
Ausmith's Avatar
I really don't care about 60 ft times....
Matt how much impact did they have on the stability/ridgity of the font end on the track?
Old May 10, 2002 | 07:46 AM
Dropspeed's Avatar
Default Re: z10 tracktion bars??? (Ausmith)
I ran a 2 day event at Gratton (MI) and was concerned they might act like a front swaybar causing the car to understeer/push. The best way to describe it was I would come up to a corner, brake, Turn the wheel and hit the gas again, the car would turn 90 degrees and shoot out of corners like a rocket. It felt like the drive wheels were glued to the ground. I was able to run 1:29xs out at Gratton, which is faster than I have ever run there.
Mattj
Old May 10, 2002 | 08:29 AM
Nighthawk GS-R's Avatar
New User
whats the cost of them??
Old May 10, 2002 | 08:33 AM
AssPenny's Avatar
Default Re: z10 tracktion bars??? (Nighthawk GS-R)
About 350 I think.
Craig - Who got his along time ago in a group buy when they first came out.
Old May 10, 2002 | 08:42 AM
R134's Avatar
Just picked some up. $336 shipped
