92 EG Hatch w/D16y8 rev limit at 3500, code 10, 16, 41 Need advice...
Old Nov 30, 2006 | 04:07 PM
06Xrunner's Avatar
Default 92 EG Hatch w/D16y8 rev limit at 3500, code 10, 16, 41 Need advice...
I have a 92 Hatch that I just purchased, it has a d16Y8 from a 96+ EX. When I purchased it she came with a P06 and no dist. I purchased a 96+ Dist removed the 2 large pins and put them into the correct plug. It all plugs in, I also purchased a P28. It starts up and seems to run fine but when I give it any gas when its sitting it revs to 3500 and hits rev limiter. It also comes up with the code 10, 16, and 41. Any help would be greatly appreciated.
Thanks!!!
Old Nov 30, 2006 | 04:17 PM
flatblack-h22's Avatar
Default Re: 92 EG Hatch w/D16y8 rev limit at 3500, code 10, 16, 41 Need advice... (06Xrunner)
fix the code.
10 IAT - intake air temperature sensor
16 Fuel injectors
41 Primary oxygen sensor heater
car is in limp mode probably
Old Nov 30, 2006 | 09:27 PM
06Xrunner's Avatar
Default Re: 92 EG Hatch w/D16y8 rev limit at 3500, code 10, 16, 41 Need advice... (mr.EGg)
Thanks, any idea on which one I should go for first?
I looked at the IAC and it appears to be connected to both hoses and the wiring. I personally have never heard of the IAC going out.
I inspected the wiring going to the injectors and they all seem to be connected. If one of them werent working wouldnt it run like crap? It seems to re running a little rough but not like its only on 3 cylinders.
Do you think a wire or wiring could be causing false codes?
THANKS A MILLION!!!
Old Dec 1, 2006 | 12:47 AM
06Xrunner's Avatar
ttt
Carathos
Jun 2, 2009 05:04 AM
codrulz
May 3, 2009 12:55 PM
92CiVicSI79
Oct 27, 2008 09:01 PM
96tegsr
Aug 14, 2003 12:32 AM
