Honda Fit Honda Fit (Jazz)
Aftermarket Fit Brake Pads: same as base rsx
Old Nov 30, 2006 | 02:48 PM
BoostLE's Avatar
Default Aftermarket Fit Brake Pads: same as base rsx
I just mounted a set of Hawk HPS pads made for the 05 RSX Base and it fit's perfectly.
The PN for the HPS is HB418F.646. Time to go find some Hawk Blue's for saturdays time attack.
Old Dec 1, 2006 | 08:34 AM
yobtah's Avatar
Default Re: Aftermarket Fit Brake Pads: same as base rsx (BoostLE)
Yep... the Fit uses 10.3 inch diameter front rotors. That's the same size used by the base RSX and some Civics also. I'm betting it's the same front brake setup.
Old Dec 4, 2006 | 05:53 PM
yobtah's Avatar
Default Re: Aftermarket Fit Brake Pads: same as base rsx (JJDrivesAJazz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJDrivesAJazz &raquo;</TD></TR><TR><TD CLASS="quote">i just had a crazy idea of taking the front suspension apart, and mounting the rsx-base 5 lug hubs and remounting everything else</TD></TR></TABLE>
That probably wouldn't work. While the rotor and caliper seem to be the same as the base RSX, the hub, wheel bearing, and steering knuckle likely are not. At best, you'd need to press out the Fit's wheel bearings and hubs and press in the RSX parts, but that's assuming the bearing sizes are the same. They probably aren't because the RSX is a heavier car running larger and heavier wheels and tires.
Here's a picture of the Fit's steering knuckle: http://www.bernardiparts.com/S...4.GIF
The brake rotor mounts to part "2" and the rotor attaches to the hub on the bearing spinning in the big hole in "2". The actual part labeled "2" and the bearing inside is probably different from the corresponding parts on an RSX, however.
Old Dec 4, 2006 | 10:18 PM
ricecooker415's Avatar
the rsx hub is larger then the fit hubs, and even if that wasnt the case, you would have to deal with the spacing between the bracket and rotor.
JOS3d17
Honda Civic (2001 - 2005)
Apr 7, 2012 11:55 AM
kkim
Honda Fit
Dec 4, 2006 01:40 PM
aZnjCC
Nov 3, 2004 12:56 AM
drunknbass
Dec 14, 2003 10:14 AM
