LS Intake Mani On A Vtec B-Series Head, Can It Be Done?
I'm looking at a set of ITBs for a LS and want to know if you can make them fit a Vtec Head. I know you can modify a Vtec IM on an LS head but whats needed to do it the other way around? Thanks.
Im sure if you wanted to cut the flange and weld it or seriously change the LS parts to fit the B16 it couls happen.
But if you are asking can it bolt up --- no sorry different pattern and gasket.
I've seen B16 intake manis on LS heads, the cut the dizzy sade and add a plate, I'll try to find a link to it.
