Oil temp
Old May 9, 2002 | 07:01 PM
typer77's Avatar
New User
Default Oil temp
What is the Normal oil temp, say cruising at highway speed? Weather is slightly hotter here and I find my oil temp at around 100-102 mostly... that worries me when I get on the track.. do you think an oil cooler is needed??
What about water temp?
Old May 9, 2002 | 07:03 PM
Warren's Avatar
Wrong-Way Wang
Default Re: Oil temp (typer77)
100? I don't even think that's possible. Are you sure? Where are you measuring your temps from?
Typically our cars run the oil VERY hot. 250+ on track.
Warren
Old May 9, 2002 | 07:04 PM
acura_typer's Avatar
Banned
Well, with a TypeR, you have a water to oil cooler. It should keep the temps within the rage of 220-240 at the end of a track session. I do not have such a cooler, but I do have a front mount cooler. When it was 50 outside, my temps never got over 210 for the 20 minute session. Going to the track next weekend so I'll know more then.
Old May 9, 2002 | 07:15 PM
SamB's Avatar
New User
Default Re: Oil temp (acura_typer)
typer77, do you mean 100 celsius or fahrenheit???
Isn't the usual rule that you want your oil about the same temp as your water???
Sam
Old May 9, 2002 | 09:08 PM
typer77's Avatar
New User
Default Re: Oil temp (Warren)
sorry guys, that's 100 Celsius..
I have the guages form tokyo...
Old May 9, 2002 | 10:08 PM
spoon_ek9's Avatar
Warren
yup, type r motor could go up to 140+ C after 4-5 laps
Old May 9, 2002 | 11:46 PM
typer77's Avatar
New User
Default Re: Oil temp (spoon_ek9)
wow... gasket still in one piece?
Old Nov 21, 2002 | 01:38 PM
yoshi234's Avatar
I shoot brides
was just reading the latest Option mag w/ a little article from spoon.
Mr. Spoon was saying that most non honda motors will let go w/ oil temps at 130º or more. He then went on to say that the materials used by Honda, especially in the type R motors, are so much better than other mfg's that oil temps of 140º+ and rev'ing it out to redline on the track is not a problem for DC2/EK9s. Also, he said that oil coolers are unnecessary since the potential problems outweigh the benefits. (I didn't get a chance to read further about these potential problems, since I had to get back to work )
For those knowledgable about these sorts of things, what do you think of what mr. spoon had to say?
yshi - who just shrugs *shrugs*
Old Nov 21, 2002 | 01:41 PM
Bbasso's Avatar
Default Re: Oil temp (yoshi234)
Yoshi would you have the article availible for us to read too?
Old Nov 21, 2002 | 01:48 PM
yoshi234's Avatar
I shoot brides
Default Re: Oil temp (Bbasso)
well, I didn't buy the mag...but can j00 read japanese?
Old Nov 21, 2002 | 02:00 PM
ZygSpeed's Avatar
I'm putting an additional oil cooler on the car.
Other than leaks and the potential of terminal type damage if hit in a race, I don't see too many other drawbacks.
Old Nov 21, 2002 | 02:03 PM
Chris N's Avatar
100 C is only 212 F, right? That isn't very high, at least not under track conditions.
Old Nov 21, 2002 | 03:18 PM
pinota's Avatar
Default Re: Oil temp (1107)
I´ve hit 275º F without cooler during hard runs. With oil cooler never hit more than 235º F
Old Nov 21, 2002 | 03:27 PM
Hooch'n's Avatar
Default Re: Oil temp (pinota)
Well since the ITR already has the oil cooler on it already, a potential draw back could be buying another oil cooler!
Yes, the itr has an oil cooler (stock).
Old Nov 21, 2002 | 04:33 PM
Tweakmeister's Avatar
Default Re: Oil temp (Hooch at 8400-RPM)
Ed,
I think you're going to be an exception for the no oil cooler suggestion
Old Nov 21, 2002 | 04:40 PM
Big Phat R's Avatar
Routing the lines for an oil cooler can be problematic due to space constraints - but otherwise I see no reason why an external oil cooler is a bad idea. It gives you more oil capacity too which is a good thing no?
The Spoon AP1 has an oil cooler on it - not sure about the DC2 - prolly though.
Old Nov 21, 2002 | 05:04 PM
pinota's Avatar
Default Re: Oil temp (Big Phat R)
Here´s pic of my setup. np with problematic due to space constraints .
Old Nov 21, 2002 | 06:44 PM
spoon_ek9's Avatar
Mr. Spoon was saying that most non honda motors will let go w/ oil temps at 130?or more. He then went on to say that the materials used by Honda, especially in the type R motors, are so much better than other mfg's that oil temps of 140? and rev'ing it out to redline on the track is not a problem for DC2/EK9s. Also, he said that oil coolers are unnecessary since the potential problems outweigh the benefits. (I didn't get a chance to read further about these potential problems, since I had to get back to work )
yea, oil cooler is not recommanded by spoon, i think its prolly becuase the oil presure drop, and vtec motor heavily depends on oil.
Old Nov 21, 2002 | 07:11 PM
SUPERAUTOBACS's Avatar
yes, this is what i have read too. The addition of lines and all the other components that go with can result in a loss of oil pressure. I know next to nothing on this subject matter so dont count me on this. But interesting to see that another person has the same idea.
Old Dec 18, 2003 | 10:28 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: Oil temp (SUPERAUTOBACS)
I'd like to bring this thead back to life. Has anyone had experience with finned oil pans or heat wrapping to combat on track oil temps?
Old Dec 18, 2003 | 11:01 PM
spoon_ek9's Avatar
Default Re: Oil temp (ActiveAero)
we have a special oil pan heat shield, oil temp is stable under hot day track condition.
Old Dec 18, 2003 | 11:51 PM
Daryl_SP's Avatar
How much does the oil pan heatshield go for?
Old Dec 18, 2003 | 11:54 PM
Ex-ITR5874's Avatar
Default Re: Oil temp (Daryl_SP)
Oil cooler is HIGHLY recommended !!
This is the temp after a few laps in Hockenheim in summertime WITH oilcooler...
And please don`t run that 0W30 crap... Use high viscosity oil that doesn`t smoke away when the fight gets hot (50 or better 10W60).
Old Dec 19, 2003 | 06:57 AM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default Re: Oil temp (ITR5874)
Hey whatsup Jack! How's tokyo going for ya? you picking up on some japanese? Its been a while, when you comin back into town? Its been a while since i've seen ya.
Old Dec 19, 2003 | 08:42 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Oil temp (Nvious R)
Has anyone tried putting air cooling fins on the stock oil pan? I see Spoon has a design with one that is very expensive, but by just welding on a could of small fins to the stock pan wouldn't it have a similar effect? All the fins are doing is letting heat transfer to them and letting the exposed surface area get cooled by air correct?
