EK gsr swap problems
I did a swap on a 97 civic dx witha obd2 gsr and the motor starts and runs fine but cuts out at full throttle with a 20 and 15 code I swaped ou t the computer, distribtor and fuse box but still same thing
Might help if you explained what those codes were so, we don't have to look them up.
Did you change the wiring for the IACV? D series honda's (other than the EX) use a 3 wire IACV (stepper motor), B series and EX engines use a 2 wire IACV (PWM IACV) and you have to change wires in on the harness connector to the ECU.
overdrivemag
Mar 11, 2012 04:31 PM
backagainracer
Dec 22, 2006 06:14 PM
