d-series trans
Old Nov 30, 2006 | 11:33 AM
DCSportEJ1Civic's Avatar
Default d-series trans
i taken my tranny out many times but never taken it apart. i tried the other day and i cant seam to get the top of the case off. it comes apart about an inch or so and wont come all theway apart. is there something its stuck on or is it just tight against something???
Old Nov 30, 2006 | 11:37 AM
NOFX's Avatar
H-T White Ops
Default Re: d-series trans (DCSportEJ1Civic)
You need to pull the snap ring. It holds the countershaft in place. You'll have to spread the ring and drop the countershaft.
Old Nov 30, 2006 | 11:39 AM
Ricey McRicerton's Avatar
Default Re: d-series trans (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">You need to pull the snap ring. It holds the countershaft in place. You'll have to spread the ring and drop the countershaft.</TD></TR></TABLE>
It's kind of a pain in the *** as well. Good luck with it and definately get some snap ring spreading pliers.
Old Nov 30, 2006 | 11:41 AM
Default Re: d-series trans (Ricey McRicerton)
ok thanks, thats what i thought but i didnt wanna mess anything up.
Old Nov 30, 2006 | 12:54 PM
Bense's Avatar
I use 3 flatheads.
I set the thing on the ground with a block of wood under it to prevent the input shaft from touching the ground. I then sit on a stool and place a flathead between the two trans halves
With my other hands I hold two flatheads and spread the c-clip APART. Then when I can tell that it's completely off of the bearing, I push down on the flathead with my foot and it lifts the case off.
Sounds retarded but I can do it faster this way by myself than I can with snap ring pliers and another person. Snap ring pliers spread the clip and it keeps the opposite side of the C-Clip locked onto the bearing.
Old Nov 30, 2006 | 01:05 PM
Bense's Avatar
Old Nov 30, 2006 | 01:08 PM
yengo's Avatar
Default Re: (Bense)
i've ripped them apart quite a bit and the easiest way i found out was to use a slanted needle nose plyer... stick the nose inbetween the C and into the hole then press the nose down into the hole while it spreads the clip and with your fingers open the plyers up as much as the hole will let u, than with the other hand use something flat to pry inbetween casing..
Ldo
Sep 16, 2008 12:20 PM
Ed 341
Oct 5, 2007 04:15 AM
fdavie
Aug 3, 2007 02:59 PM
EF9ZC
14
Apr 1, 2006 08:57 AM
sycamore
Nov 13, 2005 04:28 PM
