need help....fuel line question?
I am building up this shell my friend purchashed and the fuel line was cut about an inch before the fuel filter. My question is what can i do to fix this without having to replace the whole line can i use a rubber fuel line hose with hose clamps to put the two pieces back together?
This time I'll agree with Ryan and say it's not the tires...
Seriously though, don't be cheap in an area like that. Fuel can be a very dangerous thing to cut corners on. Do it right once and forget about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">yes, listen to Dave B. And if your vtech isnt popping hard after getting that fuel line, you may need to check the tires. </TD></TR></TABLE>
No Ryan, you got that a little wrong, check the tire pressure if Vtech ain't poppin!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">No Dave, you only check the tire pressure if vattack isnt LOUD. If its loud but not POPPING, then you need to check the TYRES. I would think you would know this by now??</TD></TR></TABLE>
Maybe I'm confusing it with tire TREAD...
