dx final drive in Si tranny......
Old May 9, 2002 | 06:19 PM
xXx Justin xXx's Avatar
Default dx final drive in Si tranny......
i am putting a D16Z6 in my 88 crx with a 89 crx Si tranny. I am wanting to put the final drive from a dx in there just for the low rpms so i can do some highway driving withought the high rpms. I have seen this topic on here before, where can i get the dx final, how hard is this to do, what all do i need from the dx, what year dx if it matters, and how much would a fair price be to pay a shop to do this if the tranny is already out and they don't have to put it in the car either? thanks...
Old May 9, 2002 | 06:27 PM
turbohf's Avatar
Default Re: dx final drive in Si tranny...... (The dx-R CRX)
i think it would be WAY easier to just trade someone the Si tranny for a DX. the gears are the same except the final drive...
Old May 9, 2002 | 07:06 PM
Default Re: dx final drive in Si tranny...... (turbohf)
no sir......i have a 88 dx crx. i put the Si in cuz the gears are faster. you can argue with me all you want but i have looked at rpm's for speed....Si is about 5 mph slower than dx at 3k rpms.....but the gears go faster..they are geared tighter.....my old dx tranny got thrown out tho...
Old May 10, 2002 | 05:21 AM
keithv's Avatar
the final drive affects ALL gears, so the Si tranny will be at different speeds than the dx since the final drives are different. if you don't believe me, i'll post the equation on how to find your top speed in every gear.
i have heard the si and dx gearing is the same, just the final drive is different (like turbohf said). i am not 100% sure of this, though.
i think what you want to do is swap out your 5th gear. if you want lower highway cruising rpms, just swap out the 5th gear for a longer 5th gear.
[Modified by breaka_1_9, 9:25 AM 5/10/2002]
Old May 10, 2002 | 05:35 AM
wronghand's Avatar
Breaka is right. 1st through 5th are identical in the DX and the Si. The only difference is the final drive. Your best bet would be to pick up a DX tranny. Changing out the final drive would cost more than the tranny is worth. Another option would be putting in an HF 5th gear. That would drop your Highway RPM's and not hurt your overall performance.
*Edit
By the way if you interested in a DX tranny I have a spare one and would be willing to trade for the Si.
[Modified by wronghand, 9:37 AM 5/10/2002]
Old May 10, 2002 | 05:50 AM
verseone's Avatar
hmm..i've had both trannies in my car with the same d16Z6 motor..yes i rev a lil higher on the highway..but my mpg difference isnt very noticeable. i dont burn that much more gas with an Si tranny. i was getting about 335 miles on a full tank (89 DX) with my DX tranny and i get about 325 now? 10miles less now but i pull a whole lot harder and im not as sluggish....just my opinon
Old May 10, 2002 | 10:31 AM
turbohf's Avatar
Default Re: dx final drive in Si tranny...... (verseone)
here are the gear ratios: http://thenew.gamesbbs.com/~dmoore/tranny.htm
Old May 11, 2002 | 05:25 AM
Mista Bone's Avatar
D Tranny Guru
BTW DMoores page is incorrect for the 92-95 DX,CX,VX trannys.
He knows, just never bothered to update.
EX/Si
1st-----3.250
2nd-----1.900
3rd-----1.250
4th-----0.909
5th-----0.750 for Si HB and Del sol Si
or------0.702 for 2 dr or 4 dr sedan
Final Drive---4.250
DX
1st-----3.250
2nd-----1.762
3rd-----1.172
4th-----0.909
5th-----0.702
Final Drive---4.058
CX and VX
1st-----3.250
2nd-----1.761
3rd-----1.066
4th-----0.853
5th-----0.702
Final Drive---3.250
Old May 11, 2002 | 06:44 AM
Mugen Dom's Avatar
Default Re: dx final drive in Si tranny...... (Mista Bone)
si gears are same as teh dx...
1st 3.250
2nd 1.894
3rd 1.259
4th 0.937
5thh 0.771
reverse 3.153
finaldrive 4.250
(DX final drive drive 3.890)
Old May 11, 2002 | 08:17 PM
Nossy's Avatar
Default Re: dx final drive in Si tranny...... (jdmB18hatch)
don't swap out the final drive....just get some bigger rims/tires
Old May 11, 2002 | 08:28 PM
.ShawnD.'s Avatar
Default Re: dx final drive in Si tranny...... (Nossy)
well hes got 17's .. he just needs a 5th gear the one he has it pretty rough..
Old May 11, 2002 | 08:51 PM
Default Re: dx final drive in Si tranny...... (shawnD)
yea, it is 4k rpms at 81 mph. my dx 5th was like 4k rpms at 96 mph. big difference, but i noticed a big difference as far as pull and getting through gears when i put the Si tranny on it. but hell....right now i would just be greatful if i could ever figure out the wiring on my new engine so i can at least drive it..... the new topic is 92-95 civic ecu harness.....help me out!!!!!!!!!!!!
Old May 12, 2002 | 04:34 AM
wronghand's Avatar
Hey man let me know if you are interested in the DX tranny. I can drive to kernersville to make the trade.
Thanks
Old May 12, 2002 | 07:37 AM
Default Re: dx final drive in Si tranny...... (wronghand)
na man. like i said, i have had a dx tranny ( my stock one), i am keeping the Si just because it has low milage and i like the gearing 1-4th, i guess i'll just have to live with 5th. thanks though.
Old May 12, 2002 | 07:58 AM
zcivicz's Avatar
so why does the 5gen civic Si use the same gear ratios as the 4gen DX tranny if the 4gen Si tranny has better gearing??
what does FINAL DRIVE mean anyway ???
[Modified by zcivicz, 4:58 PM 5/12/2002]
Old May 12, 2002 | 08:00 AM
wronghand's Avatar
Oh ok, I thought you said that your dx tranny got thrown out.
Old May 12, 2002 | 11:58 AM
Nossy's Avatar
Default Re: dx final drive in Si tranny...... (zcivicz)
I'm guessing for gas mileage, since every auto manufacturere has to conform to standards every year etc.
Old May 12, 2002 | 12:16 PM
it did, but i'm saying that i do not want to get rid of the Si tranny. I love the gears for racing, just wanted lower high way driving and a higher top speed now that i'll have the power to turn it.
Old May 13, 2002 | 01:45 PM
keithv's Avatar
the final drive is somewhat of a "divider" for the gearing. the higher the final drive, the shorter the gearing.
Old May 14, 2002 | 06:42 AM
Mista Bone's Avatar
D Tranny Guru
redline 5th in the Si tranny, then we'll talk.
Old May 16, 2002 | 02:38 PM
as soon as i get my wire harness back next week, i guess we'll have to talk..haha. why do you know what the top speed was? i know the crx Si engine red lined 6,500 rpms, keep in mind that now i have 7,300.....
Old May 17, 2002 | 03:37 AM
Mista Bone's Avatar
D Tranny Guru
well, MSD 6AL currently set at 7800 rpm, pull the chip from it and I'd have 8500 rpm via ECU.
I've seen 140+ once, now I don't even try anymore.
Tuner Eddy
20
Jan 28, 2007 02:47 PM
Jet Black
16
Jan 7, 2004 10:40 AM
ViperRedCRX
Jan 13, 2003 12:01 PM
maximedx
15
Oct 12, 2002 06:46 AM
serious
14
Jul 17, 2002 03:31 AM
