looking for info on putting an itr into a 90 civic
Old Nov 30, 2006 | 06:19 AM
lrcrx90's Avatar
Default looking for info on putting an itr into a 90 civic
sorry if i'm in the wrong forum but i was planning on putting a jdm itr into my civic. i just needed info on part list needed and info on tuneup clutch flywheel ect. would i buy it for a usdm swap or it dosn't matter. i plan on getting the 96-97 swap.
Old Nov 30, 2006 | 06:24 AM
exies's Avatar
You are definetly in the wrong forum for this. Check out the Hybrid section of H-T. I'm sure you'll find alot more help there. Maybe you could also try a search in that section as well.
https://honda-tech.com/zeroforum/18
Good Luck
Old Nov 30, 2006 | 06:53 AM
crxgator's Avatar
Default Re: looking for info on putting an itr into a 90 civic (lrcrx90)
do a search for posts in the CRX/EF forum...
Old Nov 30, 2006 | 09:01 AM
LunchboxZT's Avatar
Default Re: looking for info on putting an itr into a 90 civic (crxgator)
My god you're going to put an entire Integra Type-R inside a Civic?? What kind of Civic is this??
/snicker
Old Nov 30, 2006 | 09:11 AM
1GreyTeg's Avatar
won't fit, maybe a CRX might though
Old Nov 30, 2006 | 09:28 AM
lrcrx90's Avatar
its a 90 civic sedan and would it fit the crx and not the civic i ain't gonna have a/c powersteering
Old Nov 30, 2006 | 09:36 AM
crxgator's Avatar
Default Re: (lrcrx90)
ok, that's fine, there are many step-by-step topics if you search the archive crx/ef civic forum...
Old Nov 30, 2006 | 09:50 AM
lrcrx90's Avatar
crxgator do u have a itr?
Old Nov 30, 2006 | 09:59 AM
lrcrx90's Avatar
i checked out the crx/civic forum and all they have is b16 into a 88-91 civic/crx nothing on the itr
Old Nov 30, 2006 | 10:32 AM
lrcrx90's Avatar
i know that i need the hasport b-series hydraulic mount kit and shift linkage.rywire does the wiring for the plug and play option. and as far as axles and half shaft goes would i use it from a 90-93 teg or not. also the installation is it the same as the b16?
Old Nov 30, 2006 | 01:22 PM
lrcrx90's Avatar
so nobody has any answers
Old Dec 1, 2006 | 09:47 AM
kulrevon's Avatar
it is basically the same as any b series swap. you need linkage mounts and rewire the harness. find an ecu you want to run and tune it.
Old Dec 1, 2006 | 03:33 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (kulrevon)
you're also going to have swap over the injector plugs from your civic to the ITR's and get rid of the resistor box.. Also the alternator plug is different than your wiring on the 90 so you'll have to swap over the plug housing.
Old Dec 2, 2006 | 10:56 AM
lrcrx90's Avatar
anything else i need to do
Old Dec 2, 2006 | 05:57 PM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lrcrx90 &raquo;</TD></TR><TR><TD CLASS="quote">anything else i need to do</TD></TR></TABLE>
Yea, search and read
It's pretty much the same as any B series swap.
For wiring, give rywire a try if you have doubts about wiring. Mechanically, the swap is a peace of cake. It's just old bolts that might give you trouble.
Mechanically:
- Remove/unplug wires and hoses
- Remove header
- Remove shift linkage
- Remove axles
- Remove hood if you want, I would.
- Secure motor with a hoist.
- Once secured ubolt the mounts (4 of them)
Install is the opposite. You may want to remove the radiator just to give you a little extra room. Also, follow the Hasport directions and pound in the driver side wall a little.
It's really easy, especially if you have someone else do your wiring.
dfJDM
Oct 27, 2010 11:49 AM
dinamic_ed3
Oct 14, 2010 08:30 AM
Slowass4dr
Sep 21, 2005 06:48 PM
hatchbacksir
Mar 18, 2004 08:40 AM
crxforum
Sep 17, 2002 01:28 PM
