minimum piston to head clearance in itr
AFAIK, stock piston to head clearance is 0.059". What should be a safe minimum using stock rods with ARPs revving to 9000 max? I'm asking this to know how much should I mill the head to raise CR but staying within safe limits. Endyn recommends 0.045" with stock rods.
Unless you are talking about an 84-85mm block with a stock chamber ITR head, the ITR head doesn't have any quench so the piston would really have be sitting above the deck to even start to have clearance issues.
itr1244
Apr 6, 2007 10:07 AM
