Stock Fuel Pressure
Old May 9, 2002 | 06:10 PM
SuperRice's Avatar
Default Stock Fuel Pressure
I did a search and nothing came up, does anyone know what the stock fuel pressure is for the 99 Civic EX and what should I set it to with just I/H/E?
Old May 11, 2002 | 11:20 PM
SuperRice's Avatar
Default Re: Stock Fuel Pressure (SuperRice)
anyone??
Old May 12, 2002 | 01:46 AM
madtownhonda's Avatar
stock: about 40psi @ idle, 45psi @ WOT
Old May 12, 2002 | 04:47 AM
DragII's Avatar
25 Year Member
actually for a sohc, stock is only 28-36psi.
Old May 12, 2002 | 09:58 AM
Default Re: Stock Fuel Pressure (SuperDragII!!!)
specs per Factory Service manual 38-46psi
Old May 12, 2002 | 12:46 PM
DragII's Avatar
25 Year Member
Default Re: Stock Fuel Pressure (madtownhonda)
for a gsr and Type R
SOHC of all kind are 28-36psi or are you reading the "vac line off" rating which is 36-48, yet not the number you are to be concerned with.
acmoc
Jan 21, 2012 02:25 PM
hondaz6lx
Jan 29, 2007 05:05 PM
UNVMYR
Nov 22, 2002 12:11 AM
Malice
Dec 21, 2001 12:06 PM
