gsr/type r questions.
Old Nov 29, 2006 | 10:37 PM
dontgodumb's Avatar
Default gsr/type r valve-train questions.
Im planning on doing a mild build on my gsr this winter, and i have a few questions before i start buying parts. My friend has brand new type r valve train (springs, retainers, and valves) and i can get a really good deal on them, but will they work with a P72 head? I plan on running skunk2 pro1 or pro2 cams, and was wondering if the type r valve train would hold up to the new cams, or if i would need after market springs and retainers.
Next question which cams should i go with Pro 1's or Pro2's??
I will be running PR3 pistons, stock gsr rods, and stock gsr crank. The head will have a decent port and polish and a good valve job and will most likly be milled a little to raise the compression more. I know the pro2's have to be degreed in which is not a problem, but i dont know if they will be too big for my setup, or if they would work better than the pro 1's. Any help would be great.
Old Nov 30, 2006 | 04:34 AM
b19coupe's Avatar
Default Re: gsr/type r valve-train questions. (dontgodumb)
Type R valve springs will not be adequate for Pro series cams.
Old Nov 30, 2006 | 06:57 AM
Fezzie's Avatar
Default Re: gsr/type r valve-train questions. (b19coupe)
pro2 cams, no oem valvetrain
Recaro
13
Oct 27, 2012 05:40 AM
dk=gsr
Aug 14, 2011 05:38 PM
SonicRacing
20
Mar 27, 2009 06:23 PM
ITR #1202
Mar 26, 2004 10:41 AM
crexer
Jan 6, 2003 10:11 AM
