connecting rod question.....
Old Nov 29, 2006 | 07:42 PM
powerslide360's Avatar
Default connecting rod question.....
What OEM connecting rods can replace d16y7 OEM connecting rods??? are there other d series engines that have stronger OEM rods? would any B series rods work?
Old Dec 1, 2006 | 03:50 PM
drift4jesus's Avatar
Default Re: connecting rod question..... (powerslide360)
I have heard of people machining down factory LS connecting rods to use in dseries engines but I believe the B rod has a larger pin diameter so the rods would need sleeved down.
Old Dec 3, 2006 | 07:46 PM
any other prespectives on this question? need some help!!!
Old Dec 4, 2006 | 01:51 PM
d16dcoe45's Avatar
The d16b5 which was the natural gas Civic that was only available to fleet buyers was a 12.5:1 compression motor which I *think* was similar to an hx motor (had roller rockers) and it had the beefiest oem d rods you can get. I don't know if the wrist pin diameter is the same--but you can always get them machined. They aren't as rare as people think, but since only fleets bought them--they seem to be mostly on the west coast. I looked up some of them when I was interested in buying one and putting my a6 head on to have a quick, easy high-compression back up motor--they were around $600-$1000. Im Bense--I believe he is/was building one up and can tell you more. Otherwise, I understand ZC rods are a little more robust.
1xfastxhatch
Jan 6, 2008 04:38 PM
DecentCivicZ6
Jun 27, 2007 04:22 PM
Roy G Biv
Jan 19, 2006 08:44 AM
b16sellout
Nov 9, 2004 08:47 PM
Rydaddy
Sep 28, 2003 08:09 AM
