sohc redlining at 8?????
Old Nov 29, 2006 | 07:24 PM
ph0shizzle's Avatar
Default sohc redlining at 8?????
alright my friend gots an ek with a d16y7 sohc non vtec motor. it is bone stock with i/h/e and a ecu upgrade. he says he could go 80mph in 2nd gear and 120 in 3rd gear and that he redlines at 8.. is this even possible?? i have a jdm d15b in my ek and i only redline at 7.2 and go 60 in 2nd gear..and the reason im askin is cuhz i bet him a lot of $.
Old Nov 29, 2006 | 07:28 PM
97itypeR's Avatar
oh mang. i got a stock d16y7 sohc non vtec in a ek hatch auto. and i red line at 5 in neutral. is this normal? what can i do to up the RPM redline?
Old Nov 29, 2006 | 07:29 PM
xbeamelite's Avatar
Default Re: sohc redlining at 8????? (ph0shizzle)
if he has a chipped ecu he CAN rev up to 8k...doesnt mean its healthy for the motor doesnt mean his motor is going to last very long and doesnt mean he is making any power up there anyway
Old Nov 29, 2006 | 07:30 PM
deadazleep's Avatar
the ecu upgrade is whats doing it, i beleive stock valve springs can handle up to 8k, but wouldnt think doing it on a regular basis would be good, and is he making power that high in the rpm range? if not then there's no point, i could be wrong but thats how i understand it
Old Nov 29, 2006 | 07:31 PM
xbeamelite's Avatar
Default Re: sohc redlining at 8????? (xbeamelite)
he is prolly that high becuase the dx tranny is super long
Old Nov 29, 2006 | 07:32 PM
ph0shizzle's Avatar
Default Re: sohc redlining at 8????? (civicskata)
so his car could redline at 8 and go 80 in 2nd and 120 in 3rd??? he says he does it everyday..
mugen mj5's Avatar
From: Where the shooting range is on the streets of LA, CA.
just the ecu upgrade makes it possible to redline at 8.. a modified ecu can fool the motor into thinkin that it redlines at 8 so then it does.. depends what he did to the ecu. but yah its possible. and u shouldnt have bet him money at all to prove he is wrong because he is already redlining at 8rpm that just proves to you that it is possible. geez.. oh well... good luck...
Old Nov 29, 2006 | 07:40 PM
bmw626's Avatar
Default Re: sohc redlining at 8????? (mugen mj5)
i was speeding on the highway tonight with my boosted z6 and i saw a cop as i was about to pass doing around 125ish (being dumb) and i slammed on the brakes and dropped 3rd and that was the first time my motor has ever seen 8k (chipped rev limit) stock valvetrain btw. i thought for sure i would of fucked something up.
Old Nov 29, 2006 | 07:47 PM
ph0shizzle's Avatar
but even if its able to redline at 8. does that mean he could be at 80 in 2nd and 120 in 3rd? since it doesnt produce much power after 7
Tuesdaynightfever's Avatar
Default Re: sohc redlining at 8????? (bmw626)
I have a manual EK CX with a stock d16y7, and I can vouch that in 2nd gear you can hit about 70mph (give or take) with the 6200 redline. So yes, I would say 80mph in 2nd get with an 8k redline is possible. Why he would want to redline at 8k confuses me. With just an i/h/e and ecu upgrade he will not be making power past 6200.
Old Nov 29, 2006 | 07:57 PM
Froth's Avatar
Default Re: sohc redlining at 8????? (Tuesdaynightfever)
http://www.fatboyraceworks.com/gears/
With a 175/70/13 tire, redline at 8000rpm 2nd gear tops out at 75.42 RPM
with a 185/65/14 tire, redline at 8000rpm 2nd gear tops out at 78.15 RPM
This is with the DX/LX transmission.
Old Nov 29, 2006 | 08:02 PM
turnsignalandy's Avatar
Default Re: sohc redlining at 8????? (Froth)
my y8 engine and tranny redlines at 7, 2nd gear tops 60, 3rd 90, 4th and 5th not sure.
Old Nov 29, 2006 | 08:10 PM
Syndacate's Avatar
As everybody's like "awww yeah it's possible"
It's not.
With a modified ECU you can rev up to 8k, but moving up to 8k is a whole different ball game.
With the rev limiter moved to 8k u can tap 8k no problem. Now ur putting a load on the engine and in 2nd gear ur spending TONS of time (and it is tons of time when it comes to terms w/ the engine) in the red zone.
Do that a few times and u'll throw a rod for sure .
If he's done it once or twice i can see it...but his motor's already got to getting roasted.
He can't do that **** on a regular basis anywayz.
Oh, and btw, just in case he thinks his super Y7's hot **** b/c he can rev to 8k, I'll own him in my SUPER STOCK Z6 - the Y7 doesn't even make power up that high stock, going that high is useless on a stock motor.
Old Nov 29, 2006 | 08:17 PM
Default Re: (Syndacate)
and i will waste him with my super stock y8.
Old Nov 29, 2006 | 08:24 PM
97itypeR's Avatar
my brother was on my login name, so that above post wasnt me.
Old Nov 29, 2006 | 08:26 PM
tha_badguy's Avatar
whats so freakin amazing about goin 70+ in 2nd gear
any1 with a y7 tranny can do that
its the long shitty gears
phoshizzle are you like 16 or sumthin...
Old Nov 29, 2006 | 08:48 PM
Default Re: (tha_badguy)
id rather top out at 50 in 2nd the at 70, cause ill have shorter gears, and accelerate faster, but then my gas millage will go down the *******
Old Nov 29, 2006 | 08:53 PM
dangthemang's Avatar
geeze im afraid to take my dx past 6 let alone 8k
Old Nov 29, 2006 | 09:06 PM
ph0shizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy &raquo;</TD></TR><TR><TD CLASS="quote">whats so freakin amazing about goin 70+ in 2nd gear
phoshizzle are you like 16 or sumthin...</TD></TR></TABLE>
im 17.. and i was just wonderin cuhz before i swappd to a jdm d15b i also had a y7, and it only goes to 60 in 2nd but iono i guess its jus the long gears then. but i never seen anyone go 80 in 2nd gear before
Old Nov 29, 2006 | 09:10 PM
h_s's Avatar
h_s
hey i have a b16a2 and my redlines supposed to be 8200, one time i was taking a c-rex and accord and was really late on a shift, hit 9500 and it didnt cut off.... mind you im not planning on doing that again but it may be something to do with the jdm ecu's - ive noticed im running extremely lean.. maybe the ecu wasnt tuned for the motor you or i have
mustang5.slow
Aug 22, 2007 06:54 PM
tobe1424
11
Dec 14, 2005 09:06 PM
