my 1991 accord se is busted...opinions please!!!!! ASAP!!!
my accord has something wrong, have had to many "mechanics" no-one can tell me whats wrong..it hesitates upon start...and if you press gas really hard...it will run...it also has a very high idle...input would be greatly appreciated...thanks alot!!!!
High idle all the time or just cold? Just how 'high' is the idle? Have you tried to check for vacum leaks, or unplugged the IAC to see if the idle drops?
Is it like it's flooding on start up, or a delay from when you turn the key to when the starter cranks over? any fuel in the press reg vacum line?
Come on throw us a fricken bone here
high all the time idles at like 1,500....no vaccuum leaks...i've unplugged it and it does drop a little...no clue otherwise
i am having the same problem with my 01 accord. My odometer drops below 1000 quickly. When i press the gas some times i feel like the brakes are working. i took it to a repair shop and they told me that my IAC valve is the problem and they flushed it and now its having problems again. Please help!!!!!
Got a little slack in the throttle cable?
open the top of the FITV and make sure there isn't air bypassing when the engine is warm.
smagic
Mar 23, 2008 01:35 PM
