Suspension & Brakes Theory, alignment, spring rates....
installing omin power coilovers, what bolt & nut should i use for the rear lca?
Old Nov 29, 2006 | 05:47 PM
KdiZzLe's Avatar
Default installing omin power coilovers, what bolt & nut should i use for the rear lca?
the stock rear shock has the nut welded on it and the omni power does not have that.. what bolt and nut do you guys suggest i use? this is where the shock meets the rear lca
Old Nov 29, 2006 | 05:50 PM
dvp's Avatar
dvp
Default Re: installing omin power coilovers, what bolt & nut should i use for the rear lca? (KdiZzLe)
They don't supply that for you??? That would suck.
Old Nov 29, 2006 | 05:59 PM
KdiZzLe's Avatar
Default Re: installing omin power coilovers, what bolt & nut should i use for the rear lca? (dvp)
nope.. they dont. i dont think they usually do either, im not experienced on this and havent it done one yet.. does any1 kno?
Old Nov 29, 2006 | 09:27 PM
boost'd_crx's Avatar
i put a nut and washer on it, along with the original bolt.
Old Nov 29, 2006 | 10:03 PM
KdiZzLe's Avatar
Default Re: installing omin power coilovers, what bolt & nut should i use for the rear lca? (boost'd_crx)
cool.. thanks for the input budd.. payce
Brewbot87
Suspension & Brakes
May 8, 2014 04:12 AM
CaptivaBlue
May 9, 2005 06:29 AM
CIVICon14inBRWs
Feb 3, 2005 02:33 PM
CivicEK.PDX
Sep 12, 2002 06:42 PM
