racing seat belts
Old Nov 29, 2006 | 02:34 PM
integra20's Avatar
Default racing seat belts
yes i was wondering could you put racing seat belts on stock seats? and if so how would that work thank you
Old Nov 29, 2006 | 02:37 PM
mtpktz.'s Avatar
Default Re: racing seat belts (integra20)
I do not recommend it as it is unsafe.
Old Nov 29, 2006 | 02:57 PM
Blk-dc2's Avatar
Default Re: racing seat belts (mtpktz.)
i got a set of takata harness....i bolted them up on a stock gsr seat....you just use the old seat belt bolts...
i don't know how safe it is though....
i'm only waiting on my jdm recaros
Old Nov 29, 2006 | 03:20 PM
JDM_DC4_Fanatic's Avatar
Default Re: racing seat belts (BLACK-dc2)
Reusing factory seat belt bolts will work, but it isnt the safest idea. It would be better to use upgraded hardware. Since that bolt is the diffrent between you staying alive, and you getting intimate with your windsheild.
Using a racing harness w/o a racing seat is dangerous. Also, keep in mind that the rear straps need to be set further back. I see lots of guys just bolt it right to the bottom of the seat, which, in an accident, will pull your head out through your ***. The only way to safly mount it that way, is to put the straps over a harness bar first.
Also, ALWAYS read the manufactures recommended installation instructions when it comes to any kind of safty gear.
Old Nov 29, 2006 | 04:45 PM
PrinceAli132's Avatar
When using a harness you should get a fixed back seat, and at minimum a rollbar with a harness bar.
Ali
Old Nov 29, 2006 | 04:57 PM
__oversea's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtpktz. &raquo;</TD></TR><TR><TD CLASS="quote">I do not recommend it as it is unsafe.</TD></TR></TABLE>
Luke G.
Mar 19, 2009 03:04 PM
rope74
Oct 9, 2008 02:14 PM
malubawla
Mar 1, 2006 04:24 PM
JDM96SpecCTR
Sep 20, 2004 01:32 AM
Blackdragon2000Acc
Jul 6, 2003 06:19 AM
