D16Y8 GUYS!!!!!
Old Nov 29, 2006 | 01:58 PM
ELSUICIDA's Avatar
Default D16Y8 GUYS!!!!!
OK I HAVE A 1997 HONDA CIVIC A DID A 1998 EX(VTEC ) SWAP EVERYTHING IS PLUGED IN THE CORRECT WAY. THE PROBLEM IS THAT WHEN I HIT THE CLUTCH THE CAR STALLS ON ME AT LOW RPMS BUT WHEN I HIT 3000 IS GOOD. WHEN IM DRIVING A HAVE TO HIT THE GAS UNTIL 3000 RPMS SO IT COULD NOT STALL.
*COULD IT BE THE THROTTLE CABLE THATS LOOSE*
Old Nov 29, 2006 | 02:18 PM
chinkest_raver's Avatar
hmmm your CAPSLOCK IS STUCK THATS WHY!....check you clutch. The throttle cable has nothing to with it. Did you change the clutch when you did the swap?
Old Nov 29, 2006 | 02:58 PM
ELSUICIDA's Avatar
Default Re: (*****est_raver)
nah i have the stock cluthch!!!
Old Nov 29, 2006 | 03:04 PM
ELSUICIDA's Avatar
Default Re: (ELSUICIDA)
it cant be the clutch because when i have it in neutral and hit the gas at about 2000 rpm it shudders. Also when i it the gas pedal hard, it takes a while so it could catch up.
Old Nov 29, 2006 | 03:06 PM
cranny's Avatar
24.224.233.247
could be a plug , wire , dizzy cap or rotor button , anything tuneup wise really. or could be deeper prolem.
honda00b16
Oct 27, 2010 12:20 PM
sean2000gt
Jan 15, 2009 10:55 AM
eMpAtHy
Oct 14, 2004 11:31 PM
Calavera
Feb 19, 2002 02:32 PM
