passenger side axle nut is stuck... need some help..
Old Nov 29, 2006 | 11:37 AM
type_eg_r's Avatar
Default passenger side axle nut is stuck... need some help..
i have searched but i couldn't find any tips on how do get it of besides using a breaker bar... i tried using a breaker bar and it resulted in a 1/2in. drive extension and two craftsman 1/2in. drive ratchets breaking so any tips will help out... thanks a lot everyone!
Old Nov 29, 2006 | 11:46 AM
walker111's Avatar
Default Re: passenger side axle nut is stuck... need some help.. (type_eg_r)
Go back to sears and pick up a 3/4 in T-bar along with a 3/4 in 32mm socket! You'll never need anything else
Old Nov 29, 2006 | 11:48 AM
crxgator's Avatar
drive the car up to a shop and have em zip it off for ya if the car can still be driven...
other wise get a breaker bar and like a 3 foot pole...
Old Nov 29, 2006 | 12:04 PM
type_eg_r's Avatar
Default Re: passenger side axle nut is stuck... need some help.. (crxgator)
ill be picking up the T-bar and socket! and i would drive it to the shop if it was drivable but it isn't. haha. and i did also try using the pole off my jack... thats how i broke the first ratchet. haha. thanks guys!
Old Nov 29, 2006 | 12:15 PM
Dave_B's Avatar
Call Bbasso and ask him how we got his off.
Heat torch FTW!!!
Old Nov 29, 2006 | 12:20 PM
type_eg_r's Avatar
Default Re: (Dave_B)
LOL!! heat torch?? did you just torch the nut or what? haha
Old Nov 29, 2006 | 12:42 PM
Erik95LS's Avatar
Default Re: passenger side axle nut is stuck... need some help.. (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">Go back to sears and pick up a 3/4 in T-bar along with a 3/4 in 32mm socket! You'll never need anything else </TD></TR></TABLE>
if its original, with enough miles, and siezed than theres a good chance nothing will get it off. I've had this happen twice. Still dealing with one of them.
Old Nov 29, 2006 | 12:43 PM
Erik95LS's Avatar
Default Re: passenger side axle nut is stuck... need some help.. (Erik95LS)
A very long breaker bar and a torch work wonders though. That will most likely get it or a powerful enough impact gun.
Old Nov 29, 2006 | 12:47 PM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">if its original, with enough miles, and siezed than theres a good chance nothing will get it off. I've had this happen twice. Still dealing with one of them.</TD></TR></TABLE>
Doesn't surprise me (you trying to get your nuts removed). You could always try surgery.
Old Nov 29, 2006 | 12:48 PM
walker111's Avatar
Worst I had, I could get the nut off, but I couldnt get the axle out of the hub. I ended up beating it with a sledge hammer to get it loose, then had to dremel the mushroomed end off in order to get it thru the hub
Old Nov 29, 2006 | 01:06 PM
CW-ITR's Avatar
Here, try these methods found in here:
https://honda-tech.com/zerothread?id=1352201
Old Nov 29, 2006 | 01:15 PM
RTW DC2R's Avatar
Worst I had, I could get the nut off, but I couldnt get the axle out of the hub. I ended up beating it with a sledge hammer to get it loose, then had to dremel the mushroomed end off in order to get it thru the hub </TD></TR></TABLE>
haha that sounds like something I would do
&lt;--- professional lower ball joint mangler slash dremel cutting castle nut master
never had a problem with the axle nuts though
(waits for opie to chime in)
Old Nov 29, 2006 | 01:58 PM
mugenracer's Avatar
Thats what i had to do after breaking 1 x snap-on 32mm socket and 2 x Britool 32mm sockets (all 1/2inch)....using a 3/4 bar/socket it popped off simply (after i stood on the breaker bar!!!!)
Old Nov 29, 2006 | 02:09 PM
.Ash's Avatar
Did this with a 10ft. steel sign post and it came right off. The sign post did flex a crapload first though...
Old Nov 29, 2006 | 02:20 PM
BMaDOHC's Avatar
Default Re: passenger side axle nut is stuck... need some help.. (.Ash)
buy an air compressor and a gun and you'll be all set
Old Nov 29, 2006 | 03:17 PM
dsav4shawn's Avatar
Default Re: passenger side axle nut is stuck... need some help.. (BMaDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMaDOHC &raquo;</TD></TR><TR><TD CLASS="quote">buy an air compressor and a gun and you'll be all set</TD></TR></TABLE>
that's what I did.... takes like 2 seconds.
Old Nov 29, 2006 | 03:42 PM
Dave_B's Avatar
I wasn't kidding. With a 4' breaker bar with all three of us trying to get it off together it still wouldn't budge. After that we figured a chisle (sp) gun would surely do the trick with all the vibration and all. Yet the chisle gun still by itself wouldn't do the trick. Alas though, heat works wonders.
Sorry for the shotty pic, it's all I got. We seem to think the last person that put it on was with an impact gun.
Edit: FWIW, we tried the impact gun to no avail.
Old Nov 29, 2006 | 03:49 PM
Splat's Avatar
Collector-o-Guns and Drinker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Ash &raquo;</TD></TR><TR><TD CLASS="quote">
Did this with a 10ft. steel sign post and it came right off. The sign post did flex a crapload first though...</TD></TR></TABLE>
LMAO
Smoke wrench &gt; *
Old Nov 29, 2006 | 07:12 PM
type_eg_r's Avatar
^LOL.
my sears didnt have any 3/4 t bars so i think im going to try the impact gun idea tomorrow and if that doesnt work out im going to torch that mo fo.
Old Nov 29, 2006 | 07:22 PM
type_eg_r's Avatar
Default Re: passenger side axle nut is stuck... need some help.. (CW-ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR &raquo;</TD></TR><TR><TD CLASS="quote">Here, try these methods found in here:
and that is freaking intense.
Old Nov 30, 2006 | 09:07 AM
mstewar's Avatar
Default Re: passenger side axle nut is stuck... need some help.. (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">
funny, same here.. I can destroy a lower ball joint pretty quickly.. lol..
Old Nov 30, 2006 | 09:26 AM
Erik95LS's Avatar
Default Re: passenger side axle nut is stuck... need some help.. (mstewar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">funny, same here.. I can destroy a lower ball joint pretty quickly.. lol..</TD></TR></TABLE>
me too. I've done way way too many
Old Nov 30, 2006 | 01:26 PM
Hooch'n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">I wasn't kidding. With a 4' breaker bar with all three of us trying to get it off together it still wouldn't budge. After that we figured a chisle (sp) gun would surely do the trick with all the vibration and all. Yet the chisle gun still by itself wouldn't do the trick. Alas though, heat works wonders.
Edit: FWIW, we tried the impact gun to no avail.</TD></TR></TABLE>
nice
Old Nov 30, 2006 | 03:15 PM
fled's Avatar
Default Re: (Hooch'n)
One coal chisel + One 1/2 breaker bar + One 3/4 breaker bar + One mini torch + Two different compressor and airgun rentals + Three days = the death of that ******' nut. RIP biach.
ricerodder91EX
33
Apr 14, 2007 12:24 PM
Quetzolcotl
May 9, 2006 06:04 PM
bigdogc
Jun 11, 2005 12:25 PM
VTECRaZeR
Jan 18, 2004 01:49 AM
brent_G
Apr 26, 2002 11:18 AM
