Bought Toda valve springs and titanium valve retainers to rebilt my engine.
Old May 9, 2002 | 04:38 PM
pinota's Avatar
Default Bought Toda valve springs and titanium valve retainers to rebilt my engine.
Hi, people.
Bought the Toda valve springs and titanium valve retainers to rebuilt my head, my Honda dealer is going to put all new valves too.
So bought this setup to raise the rev limit.
What do you think is safe, 9100 rpm or more, Toda say it´s safe to run until 9500 rpm.
What do you think ?
Thanks,
Pinota
Old May 9, 2002 | 04:39 PM
AssPenny's Avatar
Default Re: Bought Toda valve springs and titanium valve retainers to rebilt my engine. (pinota)
get an power enterprise belt too if you spining that high rpm. Better be safe then sorry.
Old May 9, 2002 | 04:40 PM
Willard's Avatar
9,500 sounds fine... if you are making power at that rpm.
B2FiNiTY's Avatar
I think you can handle up to 9500 no problem. What cams?
Old May 9, 2002 | 04:43 PM
pinota's Avatar
Default Re: Bought Toda valve springs and titanium valve retainers to rebilt my engine. (B2FiNiTY)
I have stock cams.
I replaced the belt last month, isn´t safe to keep it ?
Thanks,
Pinota
[Modified by pinota, 1:48 AM 5/10/2002]
Old May 9, 2002 | 04:50 PM
StinkyTofu's Avatar
I wish my honda dealer was as cool as yours...****...you can put all this stuff in your motor and still maintain a warranty?? My dealer bites your head off for having ANY little mod such as an intake.
About your timing belt, your stock one is fine, just replace it after 15k-20k. With the PE belt you don't have to change it as often.
Old May 9, 2002 | 04:52 PM
00MRSi's Avatar
Don't think the Toda valvetrain is gonna do much in gaining power without completing the package with the Toda cams. Cams gears will help you extract power from stock cams if you get dyno time. Good luck..
Willard's Avatar
the stiffer springs will add a little more stress to the belt... but with stock cams you should be fine.
9,500 will be more than enough with stock cams.
Willie
Old May 9, 2002 | 04:53 PM
pinota's Avatar
Ok, Spoon, Mugen, ECU´s have the rev limit at 9100 rpm. I think Hondata 1 stage his 9100 rpm too.
What other way to raise rev limit instead of a new ECU ?
There´s a mechanic here that can raise it on the stock ECU, but i was thinking on other ways.
00MRSi's Avatar
Default Re: Bought Toda valve springs and titanium valve retainers to rebilt my engine. (00MRSi)
Are you keeping the "stock" cams or also getting Toda B cams?
Old May 9, 2002 | 05:00 PM
pinota's Avatar
I don´t have the 3 year warranty, it´s a 98 ITR.
I have the warranty of the repair and piston change, after the detonation on the 2 pistons that melted, 4 intake and 4 exaust valves need to be replaced, i warned them about compression diferences on the other 2 cylinders and they agree to put all new 16 valves.
Lucky, hummm.
Ok, my secret is, i´m jornalist on a TV station, i drive a lot cars in a auto TV program, i have good contacts at Honda Portugal.
Pinota
Old May 9, 2002 | 05:01 PM
Black R's Avatar
25 Year Member
.....add some toda cams to that package if you really wanna make the most out of those valve springs.
Old May 9, 2002 | 05:03 PM
pinota's Avatar
Yes stock cams.
No $$$.
Ordered the DC Sports JDM SS and custom SS B-Pipe, no $$$ for that right now.
Pinota
JDMsurf
Oct 5, 2004 02:18 PM
Integra-DC5
Aug 19, 2002 06:59 PM
JDMchris
Jul 29, 2002 02:55 AM
powerfulperformance
May 5, 2002 05:16 PM
mugenintegra16
Feb 13, 2002 05:45 AM
